After I installed an aftermarket HU, using a Soundgate GMCVR2 adapter I changed my Bose 3.5" door twiddlers for Boston S35 coaxials. Since the connectors were compatible with the new speakers I just plugged them in put everything back together and figured I was done - not so fast Jack:
Put this in the "never take anything for granted" column; the C5 Bose 3.5 twiddlers do have the standard narrow/wide spade connectors - BUT the polarity is reversed from other aftermarket speakers, at least from the Boston Acoustics, so my new door speakers are out of phase with the rest of the speakers. the Bose connectors are narrow=positve, whereas the Bostons, and I assume most others are wide=positive so they are not "plug and play". I discovered this after I put everything back together and happened to look carefully at the Bose speakers I had removed. Now I need to get new female spades, take everything apart, reverse the connectors and do over. Hope I can save someone else this grief.
J, did you remove or disconnect the center channel speaker when you installed your new speakers? By disconnecting the center channel speaker the system some how throws its self out of phase.
You will see from the title that it's a C5 so no center channel. I just finished making a short harness to reverse the connectors and I installed Boston S65 coaxials in the rear as well. With my JVC NX5000 HU The sound is now awesome compared to the stock Bose - much more clarity and now I actually have highs. I can't believe how muddy the Bose sounded. My speaker shop told me that Bose stands for:
Yup, sorry missed it. Did you test the phase using test dics or other way? Where did you mount the tweeters?
I tested the phase of the speakers with an AA battery (when you apply voltage to the speaker terminals the cone moves in, or out depending on polarity. 3.5 Speaker just mounts in stock location where Bose twiddler was. If you have a C6 you can get a speaker wire harness adapter from Circuit City, Part #DW-4568SH that will let you plug them in without changing factory connectors (also works for the rear C5 speakers).
Using a battery is a good quick way to do it. Just use the + or - as a reference point for outward or inward motion and go from there.
I test phase by listening to the speakers. In-phase stereo material should sound centered and focused. Out of phase sounds dispersed and hard to focus.
If you have a DVD with some audio test tracks, you can probably copy those tracks using your sound recorder on your PC, then burn them to some tracks on a CD. Play the CD tracks and you should be able to tell the difference between in-phase and out of phase.
You guys are using 'phase' and 'polarity' interchangeably but they are not the same thing. Speakers are wired with the same or reversed 'polarity' while phase is a 360-degree issue that has more to do with time.
When wiring the speakers for polarity, all that matters is that they are the same to start with. Reversing the leads isn't relevant as long as both are done. From there, a 180-degree polarity change in one or the other might affect arrival time cohesion.
<off my soapbox>
You are quite correct Spkboy, there is more to speaker phase than polarity and I was guilty of using the terms interchangeably, however if the polarity of the speakers is not matched then it is generally safe to say that they will be out of phase, barring some bizarre setup. Thanks for the clarification.
They're already and always out of phase at some frequencies and to differing degrees due to path length differences. Reversing polarity simply changes how much that will be and can sometimes actually result in a desirable change if you have the testing hardware to see those changes.
