Sponsored by: Innova
C6 speaker replacement threads gone???
Old Aug 14, 2008 | 07:56 PM
Fawndeuce's Avatar
Fawndeuce
Default C6 speaker replacement threads gone???
Hi,
I had saved a bunch of links on how to replace C6 front and rear speakers, but none of them work anymore?
Does anyone have the info and pics? I bought the speakers and was hoping to replace the upper door and rear speakers in my coupe this weekend.
Thanks,
Paul
Old Aug 14, 2008 | 11:03 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Originally Posted by Fawndeuce
Hi,
Thanks,
Paul
They are still restoring the older threads after last week's software upgrade. They haven't been lost, just not currently available.
Old Aug 15, 2008 | 01:44 AM
Fawndeuce's Avatar
Fawndeuce
Thanks for the reply.
Can you remind me, do I have to remove the front door panels to remove the top speakers? How about removing the back ones?
Thanks,
Paul
Old Aug 15, 2008 | 07:43 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Thanks,
Paul
Yes, you have to remove the door panels to get at both speakers mounted there, the 8 or 10's in the doors (Delco vs Bose) and the 3.5" in the door panels(both).
I have a vert so I've never removed the rear coupe speakers.
Old Aug 15, 2008 | 12:03 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
rear coupe speakers arent that bad you just have to remove a few panels if you look at it it will become common sense i think you remove one panel other then the one covering the speaker, and the hatch shock has to come off to get the panel off as well
Old Aug 15, 2008 | 01:06 PM
Fawndeuce's Avatar
Fawndeuce
Thanks guys, I'll get into it this weekend.
Paul
Old Aug 16, 2008 | 01:01 AM
Grzldvt's Avatar
Grzldvt
I found the rear panels to be a bit tricky and not mangle the pin that holds the back of the panel. I am going from memory, which at my age is a bit fuzzy
First you need to disconnect the strut for the hatch. You do that by gently pulling out the clip that holds it on. You don't have to pull it all the way off, slide it out about halfway and it will allow the bottom to slide off. Make sure you hold up the side you are disconnecting. I used a 1x2 that was just about the right length to hold it open all the way.
Then I gently pulled the pins at the front of the rear panel on the B-Pillar until they were all the way out.
There is a pin at the back that holds the panel in place. If you distort the panel by pulling the front away from the B-pillar and pull it towards the back, it will slide off the holder. The pin is glued to the rear panel, if you tug at like the other panels I found that it came unglued.
For the front panels, on the left, pull the little cover by the arm rest and you wil lfind two Torx Bolts. I believe they are T-30's.
At teh bottom of teh door you wil see a slot, you can slip a body panel tool, or a very strong putty knife in there and start to pry the door panel off. It will make a horrendous noise, bit it is OK, Simply work your way around teh bottom, and both sides almost all the way to the top. Once you have the pins out all the way the panel should lift off.
On the right gently pry up the door switch and you will find two Torx. Undo those, and the drill is the same, there is a slot at the bottom to get you started.
Getting the front panel back on is a royal pain. There are hooks that need to slide over the top of the metal portion of the door panel. Someone posted that they pushed in the bottom, and the two sides as far in as they would go, then whacked the top of the panel with the heel of their hand and it pushed the panel over the top and in place.
I tried it and you really have to whack it pretty hard, but it works.
I spent at least 10 minutes, and more words than the neighbors have ever heard out of me trying to get the top of the panel hooked first then slide in the pins.
Hope this helps, and again this is from memory from several weeks ago of installing new speakers in the front, and disconnecting the rears. For my taste the rears just screw up how I want my music to sound.
To C6 speaker replacement threads gone???
