Sponsored by: Innova
2005 XM install issues
Old Aug 15, 2008 | 09:56 AM
tut69's Avatar
tut69
3rd Gear
Default 2005 XM install issues
I'm having trouble with so many conflicking stories on adding XM box to a 05 C6 with standard Bose/6 disc radio. I have an XM box from an 08, the plug is over the LR tire... What problems will I encounter installing it. I cant find a clear answer by searching. Thanks...Tim
Old Aug 15, 2008 | 10:04 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
My understanding of the XM tuner boxes is that they cannot be re-programmed to move them between cars the same way radios can. I was looking to sell my tuner box a couple of years back when I pulled it and a potential buyer did a bunch of research on it. The conclusion was the VIN locking on those modules is once & done. So if you have a take-off somebody sold you when they swapped to Sirius or aftermarket you may very well be out of luck.
The modules ARE VIN-locked so if it can be done dealer programming would be required. You also will need to install an antenna.
Old Aug 17, 2008 | 09:56 AM
tut69's Avatar
tut69
3rd Gear
Default Success?
Has anyone had success with the dealer unlocking an XM unit?
Old Mar 13, 2009 | 09:39 AM
bterwilliger's Avatar
bterwilliger
http://forums.corvetteforum.com/audi...-question.html
To 2005 XM install issues
