I am trying to figure out what length of cables to order while I am at work. If you ordered cable and RCA's, what lenghts did you order? Where are your amps located? Was there excess or not enough?
always better to buy extra and just tuck the extra rca wire and cut the extra power and ground wire, for power wire just get 17 ft of it 4 gauge and for ground its really up to you where you want to ground it to i ran straight back from battery since was a better ground then under seat, dont forget to get an agu fuse holder and fuse and the remote wire for rcas, you can go like 12 feet since you run it up middle of car, i have my amp mounted on back wall
