Sponsored by: Innova
Trunk Compartment Subwoofer, C5
Old Sep 8, 2008 | 11:17 PM
CPT_Purge's Avatar
CPT_Purge
Default Trunk Compartment Subwoofer, C5
I was about to reply to a thread showing a sub installed in the trunk compartment of a C5, saying that there just isn't enough volume of air there for proper bass development. I used to build sub boxes, and yada yada, from my experience I would conclude that the trunk compartment doesn't have enough sealed air volume to get the kind of bass than any 10" sub or greater needs, maybe even an 8" but that may be marginal.
So basically, what is the general user experience of using that compartment for subwoofer operation? I'd like to put a hard grill covered by a soft grill there and should be good for a 6"-8" I suppose.
Convince me that you're really getting the true deep bass that the woofer is designed for, using this small compartment size?
Old Sep 8, 2008 | 11:22 PM
Kale's Avatar
Kale
subwoofers work well in X sized boxes. Some 10s work really well in .5, and suffer greatly in 1.0, for example.
Old Sep 8, 2008 | 11:29 PM
CPT_Purge's Avatar
CPT_Purge
I might trust an isobaric setup to use half a cubic foot at 10".
Old Sep 8, 2008 | 11:33 PM
Kale's Avatar
Kale
Many 10s are designed for optimum performance at about .5
Old Sep 8, 2008 | 11:43 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
measure it, cause ill tell u what there is deff enough space for a pair of 10s or a 12
CPT_Purge's Avatar
CPT_Purge
I haven't heard those in operation. Call me old school but it wasn't until the 21st century or very late 1990's that subs came out that claimed to require less volume behind the drivers.
I would like to hear a real high-quality real bass reproducing subwoofer that actually uses 1/2 what physics and long-time acoustics has always required: 1-1.5 ft^3 for a 10" driver. I remember when the Sub Tubes came out, the Bazooka's, yeah they delivered bass, but the punks just want bass and don't even know the quality they deliver. BOOM BOOM BOOM goes Tupac.
And of course the compartment has to be sealed. So we glue in the compartment for the sub? How is it kept air-tight? Are we lining the whole thing with dampening material because of the Fiberglass backing?
And finally, should we really be talking about 8" drivers here?
Old Sep 8, 2008 | 11:45 PM
CPT_Purge's Avatar
CPT_Purge
I only eyeballed it when I moved some tools in there after purchasing my C5 over the weekend.
Please realize I'm talking about the COMPARTMENT inside the trunk/hatchback area.
Old Sep 9, 2008 | 12:09 AM
Kale's Avatar
Kale
The compartment would have to be seriously reinforced. Putting damping material on the fiberglass and then just sitting a baffle with sub in would not be a good idea. Most people just build an MDF box inside.
Hopefully Spkrboy will be along soon to explain modern subwoofer dynamics better than the rest of us can.
And yes, we're talking about the compartment. Roughly 1 cubic foot with an MDF "flush" box inside. Enough for the right 12, more than enough for pretty much any modern 10 (1 is around the ported size.)
Old Sep 9, 2008 | 12:13 AM
pentavolvo's Avatar
pentavolvo
im well aware of what space u are talkin about and have installed a number of diff sub combos in there
Old Sep 9, 2008 | 12:18 AM
CPT_Purge's Avatar
CPT_Purge
Cool, so if you're putting pairs of 10's or 12's in there, must be isobaric. Right?
Old Sep 9, 2008 | 12:20 AM
pentavolvo's Avatar
pentavolvo
no sealed
Old Sep 9, 2008 | 12:25 AM
CPT_Purge's Avatar
CPT_Purge
<...snip for ease of forum reading...>
I had a 15" in a custom box in a Datsun 280ZX hatchback. It shook the car to pieces. And that was a 2+2. I don't see a need for a 12" in a Vette with just a 2 seater and much less ambient air space. A 10" would be more than necessary I would think. I'd say a very high quality 8" sub would be the right way to go. Again, I'm not talking about BOOMING, I'm talking smooth deep lows and precise kicks, at Loud but not past hair-shaking.
Well that's my guesstimate until I actually install it. I'm trying to narrow down the woofer size at this point.
Old Sep 9, 2008 | 12:27 AM
CPT_Purge's Avatar
CPT_Purge
no sealed
OK you put 2 10's or 12's free-airs in that tiny space? Would like to hear it.
Old Sep 9, 2008 | 12:29 AM
pentavolvo's Avatar
pentavolvo
no sealed box ive done 2x 10s setups 2x 8s and 1x 12 setups in diff c5s
imo a baffle is a horriable idea build box out of mdf or glass it
Old Sep 9, 2008 | 12:34 AM
CPT_Purge's Avatar
CPT_Purge
How do you fit a 2 x 10 box in there?
Old Sep 9, 2008 | 12:36 AM
Kale's Avatar
Kale
like this
But with 10s flush mounted rather than the 12 in the angle ring.
sorta looks like this
But with 10s.
Old Sep 9, 2008 | 12:47 AM
CPT_Purge's Avatar
CPT_Purge
like this
But with 10s.
I just measured. It's 26" by 19" by 8"deepest after the angle ends. Why try to stuff that amount of driver into such a tiny enclosure? I think you're failing to account for the amount of woofer that is flush mounted, inside the compartment. for the 10's, you're getting much less than half a cubic foot per driver.
To Trunk Compartment Subwoofer, C5
Old Sep 9, 2008 | 12:54 AM
Kale's Avatar
Kale
For the 10s, you would want a "flush" mount. The pic above is a "stealth box" which has less enclosure space. In any case, the bottom half can be made from corrugated fiberglass which should give you plenty of strength, be light, and give you more airspace. This is my plan when I go back to a single 12.
Old Sep 9, 2008 | 01:06 AM
scott_fx's Avatar
scott_fx
how can i convince you without having you listen?
Old Sep 9, 2008 | 01:07 AM
CPT_Purge's Avatar
CPT_Purge
I would love to hear either setup. I can only imagine that it is overkill in the tiny airspace we have inside this vehicle. A quality 10" powered by a good high-power amp would be more than necessary I would think.
