Sponsored by: Innova
Eclipse CD4000 Aux Input
Old Sep 9, 2008 | 06:32 PM
LD85's Avatar
LD85
Default Eclipse CD4000 Aux Input
I have a Eclipse CD4000 and when I plug my SANSA MP3 player into the input cable, the sound is very week even with the gain at MAX.
Is there a special cable that works better or do I need the Eclipse AUX 105 cable?
Old Sep 9, 2008 | 08:27 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
is the volume turned all the way up on ur mp3 player... ive used multiple cd4000 never one issue
Old Sep 10, 2008 | 12:18 AM
Champ156's Avatar
Champ156
Check the manual, I think that radio has a source level adjustment where you can raise or lower each source seperately from eachother. thats how my Eclipse is.
Old Sep 10, 2008 | 08:00 AM
LD85's Avatar
LD85
Yes with the volume turned up all the way on the MP3, the voice part is only barely audible,, something is clearly worng, maybe it is the cable,,, the cable that I have is one that I used to split home stereo signals.
I will check the manual again for a source level adj.. too
Old Sep 10, 2008 | 09:44 AM
pentavolvo's Avatar
pentavolvo
there is a way to adjust source level in unit from like low to medium to high but something else is clearly wrong, trust me even with the unit on its default of low if should be damn near just as loud as cd's
Old Sep 10, 2008 | 11:59 AM
LD85's Avatar
LD85
thanks, I will check it out this weekend.
Old Sep 12, 2008 | 06:23 PM
LD85's Avatar
LD85
Tried a new RCA monster RCA to Mini input cable and it works fine.
To Eclipse CD4000 Aux Input
