Sponsored by: Innova
DC-DC converter question
Old Jan 11, 2002 | 07:41 PM
Timothy2468's Avatar
Timothy2468
Default DC-DC converter question
Just upgraded entire system. I concealed an Alpine CDA 7876 HU in the ashtray compartment. Sounds great! Alpine has an upgraded model(CDA 7977) that has 4volts running to ALL of the preouts on a separate DC-DC converter. My 7876 has 4volts to my sub preout and 2volts to the other 3. And it doesn't say anything about a DC-DC converter. My question: What is a DC-DC converter and would I notice any difference in sound quality if I would choose to swap out one for the other?
Old Jan 11, 2002 | 11:45 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: DC-DC converter question (Timothy2468)
You would want to have higher volt outputs if you are going to split the signal such as running it through a crossover to multiple amps. In most situations it shouldn't make much difference.
Old Jan 11, 2002 | 11:52 PM
AP's Avatar
AP
What type of Vette C1-C5 did you get the HU to fit in the ashtray... I want to add a DVD in the dash area but keep it hidden... I will place the screen in the main HU section ... and a DVD in the ashtray would be great...
Thanks...
Oh... Sorry.. I just read your profile... a 99C5...
Do you have any pics? Is there enough room in their for the HU?
[Modified by NewVetteLover, 10:56 PM 1/11/2002]
Old Jan 12, 2002 | 10:03 PM
alanmeyer's Avatar
alanmeyer
A DC-DC converter (spoken "DC to DC" converter) is an electronics circuit or module that is designed to create one or more DC voltages from another. For instance, a DC-DC converter could be something that takes 13.8V DC as an input, and creates +8V DC and -8V DC outputs.
For the most part, DC-DC converters are used as small power supplies. Another aspect to DC-DC converters is that most models are isolated from input to output. What this means is that the ground reference between the +Vin and +/-Vout voltages do not have to be tied to the same ground. This is a useful feature if the goal is to isolate two electronic systems.
To answer your second question, the sound quality is obviously designed to be better with a higher voltage output, and the head unit will undoubtedly sound "different". However, "better" is subjective and I suggest that if you like what you currently have, then leave it alone and feel good about what you have. The DC-DC converter could be more hype than performance.
To DC-DC converter question
