Sponsored by: Innova
Help with C5 speakers and sub combo
Old Oct 31, 2008 | 04:41 PM
Vortech C5's Avatar
Vortech C5
Default Help with C5 speakers and sub combo
Hello,
I have a 2000 C5 hardtop and I made the following modifications...
Pioneer D1 double din unit/console
PAC interface allowing the use of the factory BOSE speakers
Nakamichi 2 Ch. amp powering a 10in. Nakamich sub.
Now for the issue.....
The door speakers sound muffled and "not right." The bass is great; however, everything else sucks....
I know the best solution is to add another amp and put components in my doors; however, I was wondering if there is another solution?
Perhaps I can get rid of the PAC and run 2-way speakers in the doors and run it off of the head unit?
Anyone have experience doing such a thing?
Thanks in advance
Old Nov 1, 2008 | 02:12 PM
RichDash's Avatar
RichDash
Did you blow the speakers or do they just sound like crap to you ?
Old Nov 1, 2008 | 03:00 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
the only thing the pac adapter is doing is running ur bose subs in the doors the twiddlers are powered straight from the radio, id check some radio settings see if the bass boost or something is on, otherwise i woudl rip the bose stuff out of the door and put a 6.5 coaxial in the door and power from radio or ideally 6.5 components set and amp it
Old Nov 2, 2008 | 10:47 PM
catch06's Avatar
catch06
Same thing happened to me, fronts sound very soft, not clear, tried many different settings, do you recommend any particular speakers?
Old Nov 4, 2008 | 02:02 AM
jpandes's Avatar
jpandes
Old Nov 4, 2008 | 03:23 PM
pentavolvo's Avatar
pentavolvo
IMO you really need to do an amp and components, otherwise a set of 6.5 coaxials off the deck would work as well but IMO it may not get loud enough for you
polk db651 gets my vote for a cheap coax that works well
To Help with C5 speakers and sub combo
