Sponsored by: Innova
Aftermarket radio help?
Old Jan 12, 2002 | 10:42 AM
RockeVette95's Avatar
RockeVette95
Default Aftermarket radio help?
I had a very reputable stereo shop tell me that the factory radio would have to be disassembled and a plug-in circuit board removed so the car woul run correctly if I install an aftermarket radio????????
Any truth to that? Also are there any install kits that provide a pocket under the radio instead of just a blank plate and who has them???
Can anyone give me detailed info on the sys flash fix?
_______
[Modified by RockeVette95, 8:46 AM 1/14/2002]
Old Jan 12, 2002 | 12:07 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: Aftermarket radio help? (RockeVette95)
First, welcome to the forum!
Well, the installer was partially correct. If you simply remove the radio, the SYS light flashes on your display. It doesn't do anything more, but it can be annoying. Somewhere on the forum there is a fix to that involving a resistor. I need to look that up myself again because I'm about to start the install on my '92.
I think Metra sells a kit that has a pocket under the radio for single DIN setups. http://forums.corvetteforum.com/zerothread?id=186002 That was for a C5, but they may have something for a C4. Good luck!
Sweet car you have there by the way! :D
Old Jan 13, 2002 | 03:06 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Aftermarket radio help? (92Shawnster)
Some cars have this problem, some don't. Its a 50 cent resistor fix if you do get it. I never had a problem with mine.
To Aftermarket radio help?
