I am replacing my factory system with: Kenwood x592 hu, Alpine pdx-5 channel amp (75x4,300x1), jl 10w3v3 sub, 8" 3-way in doors, 6.5 midbass in rear. I am not looking for the ultimate system, just something better than stock. I was told at the local audio shop, I need a wiring adapter (factory-aftermarket HU), Antena adapter, faceplate adapter, and to run all new wiring. After reading all the posts on here, I am at this point I would do all the installing myself if its that easy. Do I need to splice, get other adapters, or what? Please help! This is my winter project and would like it to stay that way.
correct you need a dash kit, gm wiring harness, gm antenna adapter, wiring kit. also if i read this right u are putting 8" coaxials in the door and a 6.5" midbass in the back? if this is the case u really need to reconsider this imo
Is there something wrong with this set up? There will be a 10" sub in the back. A guy at the local stereo shop said this set up would work great. I was given a quote of $1,700.00 plus labor.
comp up front leaves you 100s of options literally. Components will sound better then coaxials any day of the week, a seperate tweeter and midwoofer will produce far better sound then a coaxial will. I guess going with an 8" component said could be done but they are pretty rare, imo a quality 6.5 components set will get you way further then 8 coaxial will
that comes out to under 700, do some ebay shopping and you should come out pretty good.
Sub box from NVTHIS
roughly 150 if i recall maybe less, get a set of speaker plates, i can make you somre for cheap
wiring plan on 100 ish
The polk IMO gives u a great bang for the buck, this setup will blow stock out of the water and for most ppl would be way more then enough. If you ask me this will sound alot better then what the shop suggested
I want a 5-channel amp around 500-600 watts. I like the idea of saving space and having 1 amp. I do want to have the rear speakers. Nothing is set in stone. I am always ready to listen to others opinion.
Those items look very nice! I do have front speaker plates and a sub box, first thing I did. The plates have not been cut for speakers yet. The sub box is a custom one waiting for a final speaker size. Whats with the wiring plan?
