Sponsored by: Innova
JL Audio Stealthbox install
Old Nov 23, 2008 | 03:05 PM
TheCartel's Avatar
TheCartel
Default JL Audio Stealthbox install
I have a JL Audio Stealthbox That I will be installing in my 99 coupe. It has the cd changer in the back. Waht all has to be removed to drop the box in? The changer, brackets, Gray carpet pad need to come out? Total newb to the stereo world.
Old Nov 24, 2008 | 08:34 AM
Gideon's_Test's Avatar
Gideon's_Test
If the JL audio stealthbox is the same as the regular stealthbox, all you need to remove is the CD changer and the CD changer bracket...
Old Nov 29, 2008 | 10:35 AM
TheCartel's Avatar
TheCartel
I ended up having to remove the gray pad thing that's in the well. Once I did that it fit perfectly. I can't believe how tight that box fit's excellent construction.
To JL Audio Stealthbox install
