Sponsored by: Innova
Stock Nav Removal - Stuck - PLEASE HELP
Old Jan 12, 2009 | 07:35 PM
ilovemyredhotc6's Avatar
ilovemyredhotc6
So. Cal. Events Coordinator
Default Stock Nav Removal - Stuck - PLEASE HELP
Hi,
I'm in the process of removing the stock nav to put in a DNX-8120. I have the center console removed as well as the A/C unit, and I have removed the stock navigation. I still need to get the nav antenna off from the air duct area. Is there any way to do this without removing the entire dash.
Thanks,
Dave
Old Jan 12, 2009 | 08:20 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
gotta remove the dash to remove the antenna just leave it trust me its not worth the trbl
i assume ur stuck removing the standard antenna, try twisting a bit back and forth and just pull hard i have had to use pliers more then once, i woudlnt be scared of damaging it honestly
Old Jan 13, 2009 | 08:20 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
If your concern is about removing it so you can sell it drop Gene Cully a PM and get a price on a replacement GPS antenna. They're not all that expensive and probably worth it to avoid tearing up your car.
Old Jan 15, 2009 | 05:41 PM
gfroman's Avatar
gfroman
I had no trouble at all removing mine from my 08 Z06.
Used a flashlight and a long screwdriver to pop out the plastic "rivets".
Took about 5 minutes!
To Stock Nav Removal - Stuck - PLEASE HELP
