spring stereo upgrade
And yes I do like bass
thanks
Nate
thanks in advance
nate
One of the most important questions would have to be, whats your budget?
also, what kind of music do you listen to primarily?
The PG Ryval series amps are DECENT, but for slightly more money you could go with something a little cleaner and with better build quality. You might want to check out Memphis, US Amps (XT series), and Diamond Audio. They all have good quality low priced amps for your front speakers.
Generally for guys that are on a budget I usually suggest going for the best amp you can afford for your components and you can get away with "skimping" a little on the sub amp. If played side by side anyone with 2 working ears will be able to hear a difference between the quality of amps on their door speakers, where as the difference when used with a subwoofer will be much less apparent.
Which model JBL subs were you looking at?
You can also check out Image Dynamics, and Diamond Audio subwoofers, they have shallow mounting depths, are reasonably priced, and sound great.
If youre going to stick with the GT-5's wire them together (2ohms) and go with one amp. Theres no need to go with one for each, which would also save you some money.
K808 i dont know the first thing about installing so i would need someone to break down the wiring subs together and what amp would suffecient for the subs
thanks for all your help guys
Like Pentavolvo said though, take a listen to some local guys if you have a chance. Check out what theyre running and see how you like it.
Man, your responses are quick haha.
Heres a basic rundown:
First off the sub is rated at 275 watts RMS (continuous power handling).
The sub is a SVC 4-ohm
::::::: this isnt really NEEDED but just a little more info... the GT5 has a high sensitivity which generally means that you dont need a lot of power to get it going, 500w rms should do fine:::::::::::::
Basically the GT-5 subs have one set of terminals, one (+) and one (-), also called Single Voice Coil (SVC)
so.... If you have two, and wire them together in parallel
(+) to (+) and (-) to (-)
the resistance becomes 2-ohms.
So ideally you would look for an amp that gives you 500-600w RMS at 2-ohms.
Okay here we go....
Budget was accounted for, I usually recommend other brands/models but I dont think youd want to spend $600+ on one amp.
Here are some amp options, all of which I would rate better then the PG Ryval's...
::::::::::All - In - One Amps::::::::::
Alpine PDX-4.150
150w x 2 @ 4 ohm (doors)
300w x 1 @ 4 ohm (sub)
Roughly $450-$500
Eclipse XA5000
150 x 2 @ 4 ohm
300 x 1 @ 4 ohm
Roughly $350-$430
NOTE: Between these 2 I would go with the PDX, BUT the Eclipse isn't bad and its about $100 cheaper.
:::::::: Dual Amps, Higher Power (matching brands
):::::::US Amps
XT 800.2 (doors)
100 x 2 @ 4 ohm
Roughly $150 - $190
XT 1000D
500w x 1 @ 1 ohm
Roughly $180 - $250
Memphis Audio
PR2.100
100w x 2 @ 4 ohm
Roughly $160 - $210
PR1.500
500w x 1 @ 1 ohm
Roughly $230 - $270
NOTE: Between these two, flip a coin
::::::::: Dual Amps, Highest Power (reasonable price) :::::::::::
Memphis
PR2.100
100w x 2 @ 4 ohm
Roughly $160 - $210
PR1.1000
600w x 1 @ 2 ohm
1000w x 1 @ 1 ohm
Roughly $320 - $370
Elemental Designs
ED Nine.2
100w x 2 @ 4 ohm
ED Nine.1x
450w x 1 @ 4 ohm
900w x 1 @ 2 ohm
1200w x 1 @ 1 ohm
NOTE: These 2 choices gives you the ability to go with a more powerful sub(s) if you choose to. The negative is that this category will of course cost you the most $$$.
I think you'd be happy with any one of those choices. Consider a single amp setup if you want an easy install, and dont need more then 300 watts for your sub.
Consider the second category if you want a little more power available for whatever sub you choose... and some people just like the look of multiple amps (I know I do haha).
Consider the 3rd category if you feel you might change subs in the future and may need more power.
If you choose to go with (2) 10's OR (1) 12", you can go with 1 amp for the whole system or 2 amps (doors/subs). What it boils down to though is your sub choice, its going to depend on how much power your sub needs.
Let say you find (1) 12" sub that has a recommended RMS of 800watts, a single amp probably isnt going to cut it.
I personally like 12's for listening to all types of music, especially pop/hip-hop. If youre more into alternative/metal/rock 1 or 2 10's would work well.
Yup, you always want to look at RMS of sub and amp. Peak or Max power wont mean a thing for most people. The amps I listed have the break down of RMS @ whatever ohms (of course you can go with whatever brand you find, those are just what I felt are the most bang-for-your-buck, and also amps I would use if on a budget).
My friend was running a Diamond D6 a few months ago, good all around sub.
