Need advice on new AMP
At this time I am only using the two new speakers. My question is; 1. On the amp there is a three-position switch labled X-Over, what position is this switch supposed to, (or should) be in?
2. There are two adjustments labled, "HPF" and "LPF"....... What are they for and how do I adjust them? Do I even want to adjust them?
I have pretty much figured out the Gain and Bass adjustments, but these other ones went by me like I had it 3 speeds in reverse!
This is the very first time I have ever installed a sound system, so i'm not familar at all with what this stuff is.
Any help is greatly appreciated. Thanks, Steve
Since you are only running fronts passing full range (not setting the filters) will work fine. But as those speakers probably won't play much below 60Hz or so you could set the front to HPF at 60 to see if things sound a little better.
