Sponsored by: Innova
Powered sub question ?? Please help
Old Feb 21, 2009 | 10:34 PM
BLACK 08's Avatar
BLACK 08
Default Powered sub question ?? Please help
All I want to do is add a powered sub to give me a little more bass. My question is where do I have to hook into, the back of the head unit or do I hook up to the rear speaker to get the signal ? If I have to go into the head unit what do I hook up to ? I have an 08 with the Bose system. I am completely clueless about this stuff so please be detailed.Thanks
Old Feb 21, 2009 | 10:54 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
headunit or factory amp
Old Feb 21, 2009 | 11:06 PM
BLACK 08's Avatar
BLACK 08
Do I need to splice anything or should it have a input to hook into ?
Old Feb 21, 2009 | 11:14 PM
LTCHAPPA's Avatar
LTCHAPPA
Mine is to my Alpine HU.
Old Feb 22, 2009 | 03:01 AM
markcz's Avatar
markcz
The bass signal is not present at the wires going to the rear speakers, so stealing the signal there won't work.
You could get speaker level signal if you tapped into the bose sub wires inside the doors, or the easiest way would be to just do this
To power the sub/amp you should get the main power straight from the battery (with a fuse installed). If the sub has the 'auto turn on' feature then that's all you'd need, but that might just work if you use speaker level inputs (?). The stock radio doesn't have a 12v 'accessory power' wire that turns it ON, it listens in on the serial data line that communicates with all of the computers in the car, but it does have a 12v OUTPUT that turns on the factory amps (and stays on with RAP). You can use that signal as the trigger voltage for your new sub. I don't have my manuals with me at the moment, but you can probably find out which wire or fuse that would be with a quick search (or the C6 FAQ thread).
Old Feb 22, 2009 | 09:25 AM
BLACK 08's Avatar
BLACK 08
Thank you very much..
Old Feb 22, 2009 | 03:13 PM
markcz's Avatar
markcz
The WHITE wire at pin B3 of the radio harness is the one you need to use as your 12v trigger to turn on your new sub, just DO NOT use it to directly power the sub. That wire is the one the OEM radio uses to power up all of the other system components, and would only be hot when the radio is on.
To Powered sub question ?? Please help
