Sponsored by: Innova
need help mounting amp rack/sub
Old Apr 4, 2009 | 01:57 AM
FrankZ06's Avatar
FrankZ06
Default need help mounting amp rack/sub
I built a box that basically down the center of the hatch that houses 2 tens, an eq, and an amp. I need to mount it somehow.. I've read about putting a board underneath with some silicone, but I didn't like the way the carpet bulged up.. Is there any metal that I can mount this thing to? Can I screw something to the top of the hump behind the seat? It seems like its metal, but I figured I would ask first.. Any help would be appreciated..
Old Apr 9, 2009 | 12:51 AM
FrankZ06's Avatar
FrankZ06
anyone????
Old Apr 9, 2009 | 07:50 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Right behind the seats are the gas tanks so I wouldn't advise driving a screw into that area!
If you take the wheels off and the well covers you may find a spot that looks safe to drive a screw or bolt through a wheel hump in the trunk which you can attach a metal strap to, then secure your sub box to that.
To need help mounting amp rack/sub
