Sponsored by: Innova
Rate my C6 Nav System Choice
Old Apr 11, 2009 | 12:08 AM
gibear2k5's Avatar
gibear2k5
Default Rate my C6 Nav System Choice
I have a 08' 2LT C6 w/ Onstar w/o Bose.
Listen to Country, 70/80/90's Rock.
Pioneer Premier AVIC-F90BT
Metra TurboKits 95-3304 Car Stereo Installation Kit
Metra 40-GM10 GM Antenna Adapter
METRA Ltd 40-UV44 Motorola Antenna Y-adapter
GM OnStar / BOSE Radio Replacement Interface-model:GMAH24B
GM Class II Add-on Chime Module for GMAH24B-model:GMAHCM
Pioneer GEX-P10HD HD Radio Tuner for Pioneer HD Radio-Ready Head Units
Pioneer GEX-P920XM XM Satellite Tuner
Pioneer Premier TS-C720PRS PRS Series 6-3/4" component system FOR DOORS
Pioneer Premier TS-A532P 5-1/4 Inch 3-Way Speakers FOR REAR
C6 Speaker Mounts from nakidparts
Total w/ shipping comes to 1153.00
Are the speakers a good choice, i understand I will have no sub woofer will that affect the overall sound?
Thanks for any and all help,
Scott
Old Apr 11, 2009 | 12:27 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
go with a gmco harness instead
is HD radio in ur area, if not dont bother with it
IMO unless u are adding an amp dont bother putting components up front they are going to be severly lacking without amplification. if not adding an amp i would do polk db351 up front and polk db 521 in read and keep oem door subs going
u look at kenwood dnx series of headunits at all
Old Apr 11, 2009 | 12:53 AM
gibear2k5's Avatar
gibear2k5
I didn't think I could use the GMCO harness w/ Onstar?
Washington DC area, quite a few channels I would listen too.
I guess I need help with an amp also; not sure what to do.
Old Apr 11, 2009 | 04:06 PM
gibear2k5's Avatar
gibear2k5
Trying this again.
Polk Audio DB521 5.25-Inch Coaxial Speakers FOR REAR
Polk Audio DB351 3.5-Inch Coaxial Speakers
FOR DOOR
Keep Factory 10's
Total shipped 986.00
Old Apr 12, 2009 | 02:23 AM
pentavolvo's Avatar
pentavolvo
sorry i orgionally read it as no onstar, but if i read correctly u have onstar but non bose which means u want the gmah24 (not b) and you have a good lineup
Old Apr 14, 2009 | 07:53 AM
gibear2k5's Avatar
gibear2k5
Out of curiosity, if I went the route with the pioneer 6.5 components and amp, what amp would you recommend? And, will the bass be on par or better then the factory 8" or 10" (not sure what size) in the door? Scott
To Rate my C6 Nav System Choice
