Sponsored by: Innova
Double Din Install Suggestions
Old May 1, 2009 | 08:20 AM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
I'm going to follow the Word install instructions and see how that goes
Old May 1, 2009 | 03:34 PM
sprinter1104's Avatar
sprinter1104
Would you be willing to share your word instructions with me. It would be a huge help.
Old May 1, 2009 | 04:46 PM
Vegas Vette's Avatar
Vegas Vette
Originally Posted by pentavolvo
really you cant put factory radio back in without the brackets... ill bet u a large sum of money you can and i have done well over 20 also.. those brackets are not needed to hold the oem radio, as well drilling is just creating an expoential amount of work
Why tear up the cage if you dont have too a professional installer would not use a reciporating saw to cut up a C5 at least I dont. Useing the right size drill bit works perfict I can have all 8 rivet out in less than 30 minutes easly.
You are correct you can install the factory radio with out that support bracket but I bet you the rear of the radio would sag GM put those brackets in there for a reasion dont you think.
There is no excuse to hack something up because its a littel hard to remove! OH lets brake out
the reciporating saw and cut them out of my Corvette....NICE
Old May 1, 2009 | 10:20 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
takes less then 5 with the recip saw and if u do it right u can cut vertically right through the rivets
Old May 19, 2009 | 05:02 AM
wilsonbh's Avatar
wilsonbh
To keep my initial costs down, could the DNX6140 fit right into the slot my existing stock radio uses? Or is this talk about cutting out the brackets apply to this radio?
Would Kenwood supply a wiring harness that would allow the use of the existing speakers?
I know the Bose speakers are not well thought of but honestily, mine sound just fine to me. I'd like to keep them, at least until they start to fail.
Billy
Old May 19, 2009 | 09:12 AM
o2z51's Avatar
o2z51
Billy
They are talking about a c5, really Im not sure what directly fits in a c4, but no kenwood doesnt give the herness, i think its only like 40.00 anyway.
