Sponsored by: Innova
Antenna Adapter?
Old May 7, 2009 | 06:35 AM
hayman's Avatar
hayman
Default Antenna Adapter?
I have a 99 vert and replaced the Bose radio with the JVC KD-NX5000. I have no radio reception and I am sure the antenna is plugged in. Question; is there a difference between the Bose antenna plug to the JVC plug that I need an adapter? If so which adapter do I need?
Old May 7, 2009 | 08:05 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
antenna going up still?
Old May 7, 2009 | 08:09 AM
hayman's Avatar
hayman
yep, no problem there.
Old May 7, 2009 | 12:14 PM
hayman's Avatar
hayman
metra 40-gm10
For anyone else needing the ino
Old May 7, 2009 | 01:00 PM
Jimmy 2 Times's Avatar
Jimmy 2 Times
could have also used the scosche MDA-1B
Old May 7, 2009 | 07:39 PM
hayman's Avatar
hayman
Turns out the installer had the adapter installed but was either broke on install or was defective from manufacturer. I now have am and fm…
Life is getting better. Now I need to get the itouch adapter and Bluetooth.
To Antenna Adapter?
