Sponsored by: Innova
Crossovers; HU vs amp
Old Jun 5, 2009 | 03:14 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Default Crossovers; HU vs amp
I have a Kenwood DNX headunit that has active crossovers built in.
I'm running a 2 channel amp for the mains, and a mono amp for the sub.
Is it better to have the HU do the crossover work or have it done at the amps? Does it even matter where it's done?
If I have it done at the HU, should the amps be set to full pass?
Old Jun 5, 2009 | 06:55 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
do it at the headunit set the amps at full IMO. just remeber if ur battery dies and headunit resets crossovers reset also
Old Jun 5, 2009 | 09:21 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
It's certainly easier to adjust at the HU but my answer would be "whichever is better for your setup." Some HU crossovers are fixed, sub on or off and you can't adjust the frequency or slope. For example I run a Zapco DC1000.4 which has on-board DSP that lets me drive myself crazy with adjustability. While my Kenwood DNX8120 certainly gives me some options it can't touch the Zapco's DSP.
So if your amp gives you better options for the xover use that, otherwise the HU is probably the way to go since you can adjust it on-the-fly.
Old Jun 5, 2009 | 05:12 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Using the DSP in the Amp means fewer cables to run between your HU and Amp.
Using the HU allows you to tweak from the drivers seat, my preferred method, although some Amp DSP's can be remotely controlled.
Old Jun 6, 2009 | 02:26 AM
jdmvette's Avatar
jdmvette
Night Owl for life
thanks for all the input.
i set my main amp to full pass and have the kenwood xover at 120hz for fronts.
i have the kenwood sub xover set to 120hz, does that sound right?
Old Jun 6, 2009 | 07:16 AM
SublimeZ's Avatar
SublimeZ
From: Austin, Why are they tolling roads that are already paid for, Texas
that depends on how it sounds, but, that seems high...Try crossing lower, like 80Hz hp on fronts and 80Hz lp on the sub. Can even have a gap and sometimes sound better.(80 hp on fronts, 63lp on subs) Play with it and see what sounds best
Good luck
Old Jun 6, 2009 | 08:56 AM
pentavolvo's Avatar
pentavolvo
IMO 80hz would sound better
Old Jun 6, 2009 | 01:15 PM
Knob Jockey
If your DSP is capable, you can also use asymmetrical crossover slopes/types.
80Hz at 12 dB per octave on the sub and 80Hz at 24 dB per octave on the bass. You can still try opening the gap a little as well (90Hz on the bass) for a smoother transition.
Using a steeper high pass (aka. low cut) slope on the bass provides more headroom for that band. Placing a high pass filter on the subwoofer is also a good idea.
Using differing filter types, Butterworth, Linkwitz-Riley or Bessel for example, is common practice with many professional systems.
Crossover alignment manipulation (freq./type/slope/delay/phase) is one of the most critical aspects of speaker design/tuning. Car installations rarely allow perfect physical alignment of the drivers, so an electronic solution/compromise is the next best option.
This may seem overly complex but if you have the tools you can use them to your advantage.
Old Jun 7, 2009 | 06:01 PM
fej's Avatar
fej
Many amps come with 12db crossovers, which may not be a steep enough roll off for your mid to sub transition. Most HU's that come with built in crossovers (other than the HP/LP sub only type units) have at least 18db if not 24 (or even 48db) which gives you a lot more options and flexibility. My vette has some 24db points, and a 6db tweet highpass point due to the response and speaker positions.
Old school amps usually had better built in crossovers than the newer stuff does as well. Be sure to check your amp and HU specifications closely prior to purchase so you ensure you are getting what you want.
G'luck
Fej
To Crossovers; HU vs amp
