Sponsored by: Innova
C5 Setup Help
Old Jul 18, 2009 | 01:11 PM
MIBagentR's Avatar
MIBagentR
on my cross over box i have
input:
wf+ wf-
tw+ tw-
output:
wf+ wf-
tw+ tw-
on my amp I have speaker outputs:
ch1 +-
ch2 +-
ch3 +-
ch4 +-
I understand the outputs but what do I connect to the inputs of the crossover box?
Old Jul 18, 2009 | 02:31 PM
markcz's Avatar
markcz
Originally Posted by MIBagentR
So I decided to go with the MRP-F600 Amp and SPX-13Pro speakers.
Check out the "single input wiring connection" diagram on pg 14 of the owners manual.
Amp Ch 1 to left crossover
Amp Ch 2 to right crossover
Amp Ch 3+4 bridged to sub ?
Old Jul 18, 2009 | 04:21 PM
MIBagentR's Avatar
MIBagentR
would you set the amp to HP position (amp is used to drive a tweeter/midrange system)? or would i keep it set to off (driving full range speakers)
Old Jul 18, 2009 | 04:43 PM
markcz's Avatar
markcz
Ch 1/2 switch set to HP. If you have a sub, Ch 3/4 set to LP.
Speakers are rated at 40Hz+, the low end of the HP filter on your amp starts at 50Hz, so the speakers will be happy no matter where the crossover **** is set. Adjust it to where you think it sounds the best.
Old Jul 18, 2009 | 06:51 PM
MIBagentR's Avatar
MIBagentR
hey guys.. i got some what of an issue....
when i tried to start my car after putting everything in.. the car wouldnt start.. i heard it hesiate and then clicks came in.. I disconnected everything i did and still won't start.. I didnt touch anything other than removing the old speakers and harness and old deck.
right now i have no stereo connected and the speakers disconnected.
any thoughts?
Old Jul 18, 2009 | 09:01 PM
markcz's Avatar
markcz
Most likely... the battery is dead from the interior lights being on for most of the day while you were doing the install.
Hook the radio back up, jump the car, and go enjoy your new stereo for a nice long drive while the battery recharges.
Old Jul 18, 2009 | 09:10 PM
MIBagentR's Avatar
MIBagentR
thats what I thought too, but I had the battery disconnected most of the time. I tried jumping the car without sucess.. but I am going to charge the battery over night and see what happens in the AM
