Sponsored by: Innova
C5 Setup Help
Old Jun 17, 2009 | 08:48 PM
MIBagentR's Avatar
MIBagentR
Default C5 Setup Help
Hi - I have a 2001 c5 Z06
I am looking at the following setup:
Alpine ida-x100 deck (i don't really use CD's)
possibly Alpine SPS-500 (5-1/4" Coaxial 2-Way Speaker Set)
possibly Alpine SPS-600C (6-1/2" Component 2-Way Speaker System)
Alpine MRP-F600 (4/3/2 Channel Power Amplifier)
possibly Alpine SWS-1043D (10" Subwoofer)
My question is - do I need another amp for the front and rear speakers, or can I hook it directly up to the HU? The HU produces 50W X4 where as the speakers above show 80W each. I know this maybe a NOOB question, but just wanted to get peoples expertise.
robin
Old Jun 17, 2009 | 10:50 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i would get dedicated amp for the main speakers.
i had my kenwood DNX head unit (50w x4) driving my mains for a while after i installed my sub and there's no way in hell it could keep up without sounding crappy and distorted at louder volume levels.
the 50x4 that the alpine is advertising is peak watts. RMS is more like 18x4 and that is NOT enough.
get an amp with at least 100w RMS to keep up with the sub and you'll be much happier.
Old Jun 17, 2009 | 10:55 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
if ur buying that 4 channel amp use the front 2 ch for the front speakers and the rear 2 channels for the sub
Old Jun 17, 2009 | 11:14 PM
MIBagentR's Avatar
MIBagentR
If I use the first 2 channels for the front speakers, and the other 2 channels for the subs, what would I use for the rear speakers?
Old Jun 18, 2009 | 12:48 AM
jdmvette's Avatar
jdmvette
Night Owl for life
don't run them.
sounds better w/o rear speakers.
Old Jun 18, 2009 | 12:03 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
I have an Alpine XDA-001 and I tried to run my front components off the radio power and it sounded horrible.. You definately need to run an amp. I would run the front and rears off the 4 channel and get an Alpine PDX-600 single channel for the sub
Old Jun 18, 2009 | 04:54 PM
MIBagentR's Avatar
MIBagentR
Will the C5 alternator handle 2 the amps?
Old Jun 18, 2009 | 05:09 PM
pentavolvo's Avatar
pentavolvo
alternator can handle it all day, guys are running 1000wrms on stock alternators
what about a 5 channel amp to do it all
alpine pdx5 is a killer amp and SMALL
or the infinity 5350a
both are 5 channels that will fit under the passenger seat of a z06. i just put the infinity under a forum memebers passenger seat search for threads i have started and you should find it
Old Jun 18, 2009 | 08:40 PM
MIBagentR's Avatar
MIBagentR
I think I am going to take your advise and go with just fronts and sub with the MRP-F600
What speakers do you think I should get. I know a lot of folks are saying focal?
Old Jun 18, 2009 | 08:43 PM
pentavolvo's Avatar
pentavolvo
whats your budget. there are alot of speakers out there that will sound great and not break the bank
Old Jun 18, 2009 | 08:47 PM
Eric the Ricer's Avatar
Eric the Ricer
From: Beyonce > Taylor Swift - Welcome to the good life!
St. Jude Donor '07
2 channels for the fronts, 2 channels for the sub. No need to power the rears, you'll be fine!
Old Jun 18, 2009 | 08:48 PM
MIBagentR's Avatar
MIBagentR
I am thinking around 200-300$
Old Jun 18, 2009 | 08:52 PM
MIBagentR's Avatar
MIBagentR
another question do you think the PDX-4.100 is worth the extra $$ compared to the MRP-F600
Old Jun 18, 2009 | 09:25 PM
pentavolvo's Avatar
pentavolvo
they are both great amps, nice thing is pdx fits under passenger seat totally stealth, idk if the mrp does or not i guess i could look at dimensions
check out the elemental designs 9.65i
http://www.edesignaudio.com/product_...roducts_id=617
run them in my car and have put them in a few forum members cars, i absolutely love em
also polk momo is a really nice component set, some guys love the alpine type x
no matter what you get you could find some 50 dollar jensens its gonna sound way better then oem
Old Jun 18, 2009 | 11:11 PM
jdmvette's Avatar
jdmvette
Night Owl for life
the PDX is a class D amp which is much more efficient than the class AB F600. the PDX shouldn't get hot and overheat.
i was looking at a 2 channel PDX when i wanted a class D main amp but i went with the JVC arsenal 2 channel class D amp instead.
Old Jul 10, 2009 | 04:54 PM
MIBagentR's Avatar
MIBagentR
So I decided to go with the MRP-F600 Amp and SPX-13Pro speakers. My question is about the tweaters. Do the tweaters take a channel on the amp?
Old Jul 10, 2009 | 07:31 PM
markcz's Avatar
markcz
Default No
The amp wires directly to the crossover box. That box then sends out a wire to the driver and another wire to the tweeter. As far as the amp is concerned, you have a single 4ohm load, even though you technically have two speakers connected to it.
To C5 Setup Help
Old Jul 11, 2009 | 04:40 PM
Lancejoker's Avatar
Lancejoker
Originally Posted by jdmvette
don't run them.
This is a matter of opinion and has been(will be) debated without end. I would never think about an audio setup without the rears. Yes I've heard it,it sounds like something is missing. Oh wait,it's the rear channels missing.
But anyway,the SPX are killer speakers.
Old Jul 12, 2009 | 12:20 PM
MIBagentR's Avatar
MIBagentR
How did you guys protect the speaker from water getting in the door?
Old Jul 12, 2009 | 05:23 PM
markcz's Avatar
markcz
Water shouldn't be getting into the door
The stock grill will keep out anything other than a direct hit from a garden hose, so just be sure to shut your doors before washing the car
