Sponsored by: Innova
CD Changer plug?
Old Feb 10, 2002 | 04:30 PM
Ronnysho's Avatar
Ronnysho
Default CD Changer plug?
I'm going to be installing a Delco 12 disc changer soon as my car did not have this option installed. My service manual shows at least one of the CD changer plugs located by the right rear courtesy light. I did a quick dig around in the center storage and the little right side storage and only found plastic. Any hints? Also where is the other plug located? Thank you. Ron :seeya
Old Feb 10, 2002 | 06:26 PM
2k NMB in NC's Avatar
2k NMB in NC
Default Re: CD Changer plug? (Ronnysho)
The two connectors you need are located in the passenger footwell. Nothing is in the back of the car. The changer harness plugs into the changer (single plug) and splits into two plugs in the pass footwell area.
-GR
Old Feb 10, 2002 | 09:43 PM
Ronnysho's Avatar
Ronnysho
Default Re: CD Changer plug? (2k NMB in NC)
Any tips on routing of changer harness? Ron :confused:
Old Feb 21, 2002 | 08:45 PM
2k NMB in NC
Ron - This may be too late but here it goes....
Run the wire down the passenger side, behind the seat, and under the door trim. If you stretch the cable out first, you will see how much length you have and you can see where you have to run it.
Leave no slack when you pull the wire. You will see wire ties in the car, pass side, where the factory would have run the wire.
Old Feb 23, 2002 | 03:48 PM
Ronnysho's Avatar
Ronnysho
Not too late. Thank you Sir. Love the pewter wheels. Ron
[Modified by Ronnysho, 11:49 AM 2/23/2002]
To CD Changer plug?
