Sponsored by: Innova
Please Help with JL setup!
Old Aug 4, 2009 | 06:23 PM
FadedSS's Avatar
FadedSS
Default Please Help with JL setup!
Hey guys, I am looking to get a JL Audio 500/1v2 amp and a JL Audio 10” w3v3 sub for my z06. I have two questions:
1.Will a 250/1v2 amp be enough to power the w3v3 or should I go with the 500/1v2?
2.Should I get a 2 ohm or 4 ohm w3v3 subwoofer?
Thanks for your help!
Matt
Old Aug 4, 2009 | 08:01 PM
Mike02z's Avatar
Mike02z
Well, the w3v3 is pretty inefficient at only 85.37db so I'd probably want the 500 watt amp to power it. If you don't like a lot of bass you could get away with the 250/1. Since the amps your looking at are both Class D amps the 2ohm or 4 ohm rating should not matter as the output is the same for either a 2 Ohm or 4 Ohm load. If the sub was a dual voice coil sub or you were adding two and wanted to drive them with only one amp then I'd suggest the 4 ohm models since the JL amp is not stable at 1 Ohm.
I'm sure others will chime in as well.
Old Aug 4, 2009 | 08:26 PM
scofolo's Avatar
scofolo
A 250/1v2 would be fine for a single 10w3v3. You should get the 4 ohm. The JL Audio slash series amplifiers have the best dampening at 4 ohm and create the same amount of power anywhere between 1.5-4 ohms. So there would really be no advantage of using a single 2 ohm sub.
Old Aug 5, 2009 | 01:19 AM
FadedSS's Avatar
FadedSS
thanks for your input guys. i will go ahead and order 4ohm v3 and the 500/1v2
Old Aug 6, 2009 | 10:00 PM
08 silver vette's Avatar
08 silver vette
I just put the same set-up in my C6. I have a 10W3V3 dual 4 ohm in the JL stealth box and a 500/1. Let me say it hits harder than I thought.For 1 ten it pounds.I had a 250/1 in it first but it just wasn't enough,it would level off. So I went to the 500/1. Good move. You'll love it.
Old Aug 6, 2009 | 10:54 PM
nickwfd92's Avatar
nickwfd92
I have 2 10W3V3's with a 500/1 pushing them in a sealed box. It sounds really good and louder them my 2 10w0's i had. I love my setup now, you should be happy, I would go with the 500/1 it is a great amp with lots of power so if you want to add another sub you can and not have to buy another amp.
the tuning on the 500/1 is really good to you can really dial it in.
Old Aug 7, 2009 | 12:01 AM
FadedSS's Avatar
FadedSS
thanks for the input man. i got a great deal on the amp and sub today and cant wait to install them. do you run a battery cap or deep cycle battery as well? do your lights dim??
Old Aug 7, 2009 | 12:03 AM
FadedSS's Avatar
FadedSS
sounds great! i may have to add another 10 in the future so i am glad i went with the 500 over the 250!
To Please Help with JL setup!
