yes, I was thinking one behind each seat then two more in the hatch area?
I looked at the space behind my seat lastnight and I only see about 3 inches MAX between the firewall and the back of the seat -- depends on the angle of your seat back but as I have mine it's about 3.
So you want to put four 13" subs into a C6
That's a bit much IMHO. Most people seem more than satisfied with one 10" in such a small cabin, but if you're not 'most people', try starting out with just two of the stealth boxes in the back and you could always add more later.
Take a day and go up to Corvettes at Carlisle, I'm sure you'll see lots of different options, and I'd guess that many would even let you listen as well.
I have 1 10w6v2 in my vert with a 500/1 going to it and its way more than I can even use in my car, I have to turn the sub down most of the time. A coupe would hit even harder than a vert because of the back glass and all.
I love some hard hitting bass, but would never see the need for more than 2 10's in a vette unless it was for a show car.
