Sponsored by: Innova
Blue tooth Mic
Old Aug 13, 2009 | 11:48 AM
Texan07's Avatar
Texan07
Default Blue tooth Mic
I've reread through all the post on the Kenwood DNX installs, and yet to find out where people are installing the blue tooth mic. and push to talk button, I did see in a post somewhere the person installed his mic. at the lower kick panel near the gas pedal, not sure if this would get good reception. Your thoughts please.
Old Aug 13, 2009 | 01:35 PM
Mike02z's Avatar
Mike02z
I find the mic to be very directional. I put mine in the spot that sounded best to callers. At the base of the steering wheel. It is a direct line with my voice when I'm looking straight ahead. I don't have the button so I can't help you there.
Old Aug 13, 2009 | 07:22 PM
RyanC7's Avatar
RyanC7
I put it in the speedo cluster trim at the bottom. You can just pop off the molding around the guage cluster and run the wire there and clip it on the plastic and its out of the way.
Old Aug 13, 2009 | 07:40 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i put all BT mics in the upper corner of the pillar
Old Aug 13, 2009 | 08:00 PM
Texan07's Avatar
Texan07
I would like to locate it on the drivers pillar also but it doesn't seem to have a long enough reach, any routing help.
Old Aug 13, 2009 | 08:41 PM
fred96ws6's Avatar
fred96ws6
I have mine right above the rearview mirror and have had no complaints about not being able hear me or echos.
Old Aug 13, 2009 | 08:45 PM
spdmn75's Avatar
spdmn75
it should reach to the stock location, mine does
Old Aug 13, 2009 | 08:58 PM
pentavolvo's Avatar
pentavolvo
should reach fine, just snake it under the dash
To Blue tooth Mic
