C5 speakers, couple q's
I'm sticking with the stock bose head unit/amps. I'll be replacing the fronts with the db351's but not sure about rear.
I know the db651's will work, but not sure if it worth doing? I'd like to keep the stage up front. Would there be any improvement in mid bass with the polks?
Do the rears recieve a full signal?
The low end bass isn't there (you can't tap them for a speaker level sub input), I don't think anyone knows the exact frequency cutoff, but the rest of the signal is there and it is in stereo.
