HELP! Have no sound on C6
I tapped into the white antenna wire at pin B3, connector C1 behind the head unit for my sub amp remote and it had been working fine, but now it's not getting 12V for the remote signal and will not turn on. Also, for the sub outs I wired a high/low converter into pins A7/8 (yellow and brown) on the bose amp connector.
So far all I did to attempt to repair was remove the head unit and bose amp, and checked all connections. Everything seems to be fine, so I was thinking maybe there is a fuse somewhere (inside bose amp or nav headunit, maybe?) I don't know about.
Ideas?
If you're lucky your problem will be that you accidentally cut through the white B3 wire when tapping it
That wire is powered directly from the stock radio (which you say powers up just fine), so unless there's a bad connection or cut wire between the HU and amp, you may be looking at a problem with the HU.I'd try turning on the radio with it half hanging out of the dash and put a meter on B3 at the connector on the back of the radio. Shove a peper clip into the pin if your probe is too fat, just be careful not to short it out on anything. If you have power at the plug, then B3 is cut somewhere.
Also, on the schematic I followed, A7/8 goes to both of the L/R Rear speakers but I don't know which. The bass sounded fine when it was working last night, but the schematic I'm using is here:
http://www.corvetteactioncenter.com/...m+Sound+System
Scroll all the way down the page and click the attachment "2006premiumradio.pdf"
Let me know if there is somewhere else I should tap in.
I work on electrical problems at work every day. If a wire gets nicked, kinked, or damaged in just about any way, the area that is available to pass current goes down, which ends up creating heat, which then further damages the wire. Eventually the wire splits, just like a fuse would, when it has too much current going through it for the available area. If you used a splice tap that was a bit too small, you may have just caused the wire to split under the insulation.
One thing you can try even before getting out the meter is just cutting the white wire, 1/2" away from the splice on both sides, then strip both ends of that wire along with the new sub trigger wire, and twist them all together. Then see if everything works.
You can see ALL of the C6 schematics and plug pinouts scanned out of my '07 service manual here.
If you get everything powered up and have bass at your subs, congrats, but most others who have tried weren't able to use the rear speaker wires for a bass signal source. You'd need to use the line level signal going to the door subs, or tap the speaker level signal at the actual subs inside the doors.
Let us know what you find
