Sponsored by: Innova
FOCAL SOLID amps now available from Double D Mods!
Old Dec 4, 2009 | 12:04 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Default FOCAL SOLID amps now available from Double D Mods!
FOCAL SOLID AMPS NOW AVAILABLE
BLACK OR RED IN COLOR
2-3 weeks lead time for build
FOCAL SOLID 1$389.99
FOCAL SOLID 2 $289.99
FOCAL SOLID 4 $389.99
PM TO ORDER as these are not on website yet
FOCAL SOLID 1
  • mono subwoofer amplifier
  • 300 watts RMS x 1 at 4 ohms (470 watts RMS x 1 at 2 ohms)<LI sizset="118" sizcache="45">
  • variable low-pass filter filter (50-150 Hz, 12 dB/octave)
  • subsonic filter (35 Hz, 24 dB/oct)
  • variable bass boost (0-9 dB at 50 Hz)
  • wired remote level control included
  • Class-AB amplifier design
  • frequency response: 10-150 Hz
  • preamp- and speaker-level inputs
  • preamp outputs
  • 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
  • fuse rating: 25A x 2
  • 11-13/16"W x 2"H x 7-7/8"D
  • warranty: 1 year
FOCAL SOLID 2
  • 2-channel car amplifier
  • 75 watts RMS x 2 at 4 ohms (100 watts RMS x 2 at 2 ohms)
  • 200 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)<LI sizset="118" sizcache="45">
  • variable high- and low-pass filters (50-150 Hz, 12 dB/octave)
  • frequency response: 10-60,000 Hz
  • 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
  • fuse rating: 25A x 1
  • 8-11/16"W x 2"H x 7-7/8"D
  • warranty: 1 year
FOCAL SOLID 4
  • 4-channel car amplifier
  • 75 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
  • 200 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)<LI sizset="119" sizcache="45">
  • warranty: 1 year
