Sponsored by: Innova
Who needs stereo installs
Old Dec 22, 2009 | 05:36 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Default Who needs stereo installs
From the first of the year through the end of Feb I will be out in Atlanta and its surrounding areas anyone within a few hours drive that needs an install or help with a stereo project vet or not let me know, always willing to lend a hand
Old Dec 22, 2009 | 08:24 PM
Raccer69's Avatar
Raccer69
I am up around Knoxville and will be installing a stereo in my 09 coupe as soon as all the stuff gets here if you you want to come by and help out. Heated garage also.. Here is what I am installing
Pioneer AVIC Z110BT
PAC GMAH24
PAC GMAHCM
PAC SWI steering wheel control
Pioneer GEXP920XM
Pioneer GM5400T Amp
2 8" Kicker subs
IPOD cable
Old Dec 22, 2009 | 08:37 PM
pentavolvo's Avatar
pentavolvo
my buddy is in knoxville and we will prly travel up that way atleast once. Most likely weekend of jan 23rd, im down to help u do the install or whatever you need
just makin sure u got all ur stuff lined up, do you have wiring yet
also what sub box are u running, or building your own. are the subs 4 or 2 ohm voice coils, just want to make sure they will match your amp
Old Dec 22, 2009 | 09:31 PM
Raccer69's Avatar
Raccer69
I still have not gotten the wiring for the amp but I think I have everything else. I have speaker wire, RCA's to run to the amp. thats about all I can think of right now. It has been a couple of years since I done my last stereo install. If I am forgetting anything let me know. I will be building my own box for the subs and amp rack.
Here are the specs on the subs
8" Single 4 Ohm Comp Series Subwoofer
Power Handling:
Peak: 200 watts
RMS: 100 watts
Impedance: Single 4 ohms
here is the specs on the amp
125 Watts x 2, at 4 ohms <= 1% THD+N
380 Watts x 1, at 4 ohms BRIDGE <= 1% THD+N
75 dBA Signal-to-Noise Ratio (Reference: 1 Watt Output)
Old Dec 22, 2009 | 09:34 PM
pentavolvo's Avatar
pentavolvo
Ideally you would have gotten a monoblock amp or 2ohm subs but it can be made to work.
I assume you got decent rca's. Do you plan on adding more amps etc later or no
Old Dec 22, 2009 | 09:46 PM
Raccer69's Avatar
Raccer69
I may add another amp, door and back speakers later so I was thinking of going ahead and running the RCA's for that so I dont have to pull the console again. Yes I did get good RCA's. For what I have in the amp I can use it for something else, what amp would you suggest to for those subs. Or can I run the the subs in parallel and bridge the amp
Old Dec 22, 2009 | 09:54 PM
pentavolvo's Avatar
pentavolvo
cant run em in parallel the amp cant handle it. honestly i would keep that amp to run front speakers and add this for subs gm-d7400m, prly a bit more power then needed but will work fine, prly like 100 or so would get u some component speakers
Old Dec 22, 2009 | 10:15 PM
Raccer69's Avatar
Raccer69
Ok I just ordered the GM-D7400M. been out of the stereo stuff for a while. So since that is a mono amp and I have 2 subs they will be run in parallel? I will look around and find some component speakers for the doors. I think the factory is 6.5" in the doors?
Thanks for the info.
Old Dec 23, 2009 | 01:50 AM
FrameWise's Avatar
FrameWise
Can you make custom A-pillar's that hold Tweeters in a 2009 C6?
Old Dec 23, 2009 | 08:19 AM
pentavolvo's Avatar
pentavolvo
yup you can run them in parallel, 6.5" components is what you want. Budget?
pentavolvo's Avatar
pentavolvo
dont even remotely have the time to do it, and while on the road wont have the tools
Old Dec 23, 2009 | 05:01 PM
Raccer69's Avatar
Raccer69
As for a budget I can prob go some where around $150 for the door speakers I know that wont get top of the line but would think I could get a fairly decent set for that. Open to ideas on which ones I should go with.
Old Dec 23, 2009 | 05:30 PM
pentavolvo's Avatar
pentavolvo
edesignaudio.com e3.65i hands down best bang for your buck at that price point alot of guys who I have done installs for on here either run them or the model they replaced the edi6000s
Old Dec 23, 2009 | 07:44 PM
markcz's Avatar
markcz
If you end up in the Aiken/Augusta area shoot me a PM, I'll buy you a beer
Old Dec 23, 2009 | 08:13 PM
pentavolvo's Avatar
pentavolvo
im gonna have to make sure I do since I would love to meet up and hear ur car, bein there for 6 weeks im sure ill get bored
Old Dec 23, 2009 | 11:24 PM
FrameWise's Avatar
FrameWise
I have never done it before and have no idea of the time it would take other than I know you need to I know what you are doing to make it look perfect and sound as good as possible. Sorry if I was asking for to much. I was not implying that your time was free. I was willing to pay for your expertise.
I have just finished (for now) the complete replacement of my system and trying to find someone in north GA to do this kind of A-pillar work is not easy.
Old Dec 24, 2009 | 12:12 AM
pentavolvo's Avatar
pentavolvo
i honestly wish i had the time to do it, work keeps me on the road alot so i dont have the necessary tools with me.
http://simplicity.elitecaraudio.org/contact.html shoot him an email its on the site, he does amazing work and you may be able to send ur pillars to him and have him do them. he is one of the best installers bar none
To Who needs stereo installs
Old Dec 24, 2009 | 12:22 AM
FrameWise's Avatar
FrameWise
Thanks, that is where I am going to send them, as soon as I peel off the faux leather. I purchased A-Pillars cores but thet came in already wrapped. So I need to remove before I send out to him.
Old Dec 24, 2009 | 12:26 PM
Raccer69's Avatar
Raccer69
I ended up ordering the e3.65i's last night so now I think I have everything I need for the install except for another set of RCA's and the wiring for my amps. I will be building my boxes and amp rack next week.
Old Dec 24, 2009 | 12:47 PM
pentavolvo's Avatar
pentavolvo
you gonna make plates for the door speakers then i assume
