C5 Coupe Audio Overhaul
I measured where I wanted it and transferred that dimension set to the license plate holder. I measured the camera head (which is a one-inch cube - weird form-factor to mount) and cut a hole in the holder just large enough that the camera head was very snug.
I modified the bracket that came with the camera by lengthening the slots and bending the end of the legs 90 degrees. I found the appropriate hardware for the bracket and marked and drilled holes fot its screws and pre-threaded the license holder holes with the bracket screws.
Here's a trial fit of the camera bracket on the license holder.
I ran the camera and reverse trigger wire from the rear hatch area to the inside of the rear fascia, hooked the trigger wire to the reverse lamp, dremeled a little clearance for the camera bracket in the fascia material behind the license plate area and mounted the holder and plate back in place.
Here it is all put back together.
Unfortunately, I didn't get a chance to test it since the battery was kaput.
I took it to the parts store where I bought it 2 years ago and got a free replacement.
It's an Optima Red Top that hasn't shown the stamina my 8-year-old Red Top in my other C5 has. I'll be installing it in the morning and testing the camera so I should have more pics then.
Let me know how the images turn out, especially at night. I heard some people get glare if the license plate light shines on the camera. Also I notice a lot of OEM cameras are mounted slightly off centered and usually not in direct exposure to the license plate light.
This one is a bit washed out from the flash.
A little closer w/o flash
As a comparison, here's the OEM rearview on my Hummer.
It's mounted on the left side of the bumper ~1/3 of the way from the end and angled to compensate.
Love the remote sub level control - that is a good idea.
Unfortunately CA plates are mostly all white so a black hole in the middle would definitely draw some attention. And glad to know you don't have glare.
Originally I picked up a license plate camera but I don't want to get rid of my CORVETTE frame. Also, it might draw too much attention. And I'm thinking if some idiot tries to steal it I might drive off not knowing my plate is on the ground. Either that or keep checking my plate every time I get into my car.
So I picked up another square camera made by the same company (Farenheit CCD-4xs). It's 3/4 x 3/4 x 1 in so slightly smaller than the Kenwood. The C6 has very little room to mount anything back there so I might need that extra 1/16 to 1/8. Although it's a 160 degrees wide view camera so I hope that's not too much.
The tweeters for the factory Monsoon system in my Hummer are in the A pillar and you can definitely notice a nice improvement in the staging in that setup.
I really should learn how to take things one step at a time and not to rush into things.
I was so eager to listen to the system that I didn't pay enough attention to little details.
Now that I've spent some time listening to my system, I feel the need to redo the sound deadening.
I didn't do any of the hatch area or the cabin floors and without those, it's hard to listen to clean music at speed above 45.(I have Corsa sports on my C6)
Let me ask you all experts this; How much of a difference would it make between no sound deadening(except the doors) and an installation like Patches did above?
Would it significantly cut down the road/wind noise so that I could enjoy the music even at highway speeds?
Dan
