Sponsored by: Innova
Adding PDX-5 to 09NAV question
Old Jan 9, 2010 | 02:57 PM
CGZO6's Avatar
CGZO6
Default Adding PDX-5 to 09NAV question
PDX-5 has front, rear, and sub RCA input. Stock Nav unit only has front & rear output. Should I get a pair of Y RCA cables and run the rear output into the rear and sub input on the PDX-5? Front speakers will be PA MM6501, Rear PA MM521, Sub PA MM1040UM. TIA for the help.
Old Jan 9, 2010 | 06:15 PM
markcz's Avatar
markcz
All of the 5-channel amps that I've seen were able to feed all of the speakers even if the amp only had 2 inputs. Having said that, my Hifonics has a switch that lets you select the number of inputs (so it knows if it should supply all 5 speakers with just 2 or 4 inputs), I didn't see that mode switch on the PDX-5 pics available online, and it didn't jump out at me during a quick skim through the manual
Maybe someone who has one will know. If not, the Y-adapter will work fine.
Old Jan 10, 2010 | 12:54 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
gonna need y adapter for pdx5 done it a few times
Old Jan 10, 2010 | 10:55 AM
CGZO6's Avatar
CGZO6
Thanks for the info
To Adding PDX-5 to 09NAV question
