Sponsored by: DashLynx
C5 Amp location
Old 01-17-2010, 03:20 PM
CrazyMagMan
CrazyMagMan's Avatar
St. Jude Donor '05
Default C5 Amp location
I'm slowly getting into the audio side of things, and was wanting to keep the amp hidden from view. It appears an amp will not fit into the small compartments in the rear just from the measurements I've taken, and I'm not a big fan of it being behind the seat. Is it okay to mount the amp and a 10" sub in the center compartment in the rear?
Old 01-17-2010, 04:01 PM
Lancejoker
Lancejoker's Avatar
There are some amps that will fit under the passenger seat. I'm sure someone else can chime in and help.
Old 01-17-2010, 04:37 PM
markcz
markcz's Avatar
A 10" sub in a properly sized enclosure won't leave any room for an amp in the center tub.
The rear vertical wall is a good place to mount one, mostly out of view there.
Smaller class D amps like the Alpine PDX series will fit in the side tubs and don't generate as much heat, but they do cost more.
Old 01-17-2010, 10:29 PM
2KROADSTER
2KROADSTER's Avatar
Have you considered the center storage tub? Placed mine there and still have a little room for storage.
I utilize an ARC Audio KS 900.6 Six Channel Amp
Old 01-18-2010, 11:35 AM
CrazyMagMan
St. Jude Donor '05
I'll look into the Class D amps and then decide what to do. Not real sure at this point.
Old 01-20-2010, 07:35 PM
Chevy-SS
Chevy-SS's Avatar
Here's my solution. I am waiting for Torch Red carpet, then I will finish-fit the amp cover and completely hide the amp. The total install will be stealth.
Old 01-20-2010, 08:16 PM
Lancejoker
Lancejoker's Avatar
Just curious how you're gonna get cool air to that amp with it covered Chevy.
Old 01-20-2010, 09:42 PM
2KROADSTER
2KROADSTER's Avatar
Old 01-21-2010, 01:46 AM
pentavolvo
pentavolvo's Avatar
Cruise-In IX Veteran
5 bucks says he has zero problems with heat and that amp
Old 01-21-2010, 07:28 AM
Lancejoker
Lancejoker's Avatar
Really? Guess I'm too cautious
Old 01-21-2010, 09:20 AM
Chevy-SS
Chevy-SS's Avatar
Honestly, I don't listen at loud levels. The amp barely gets warm, so this is a non-issue for me. But if I was 20 years old and insisted on maximum volume all the time, then cooling might be an issue.
Even still, when I finally get the correct carpet, I am gonna run one continuous piece over the cover, so the front of the amp will only have a piece of carpet separating it from the cabin air.
Another thought would be to drill a few big air holes in the cover (mdf board) on each side of the amp to allow cross-flow. Ya know, I might do this just for ***** and giggles.......
Old 01-22-2010, 08:53 AM
VET IT B
VET IT B's Avatar
I am about ready to start my amp, sub and speaker replacement in my C5 Vert.
The 8" sub, sub box and amp are going in the center cubby. I wanted a stealth install.
Worried about the possibility of overheating, I am installing a mini relay at the hear unit and tapping into my REM wire that goes back to the amp. Now if I experience a overheating problem, all I will need to do is add a small 12 volt fan in the cubby to help cool and it will come on when the amp is on.
Credit is do to Pentavolvo My go to designer! Thanks Greg.
To C5 Amp location
Quick Reply: C5 Amp location
