Sponsored by: Innova
IPod Touch??
Old Jan 19, 2010 | 07:41 PM
happa's Avatar
happa
Default IPod Touch??
Im just wondering what my options are to hook up my Ipod Touch to my stock radio? Any suggestions? I did a search but didnt find my answer. Thanks
Bryan
Old Jan 19, 2010 | 08:20 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
Bryan
if you can find something that you can use the 2.5mm headphone jack on, im sure that would work.
I love my iTouch and iPhone in the car and truck.
I ditched the crappy cupholder in mine and had a dock molded in.
Old Jan 19, 2010 | 09:24 PM
aschiftner's Avatar
aschiftner
If you have a stock 12 disc CD changer, you can disconnect it and install an adapter, run the wires and you're done. I bought mine at Best Buy for $100. It was made by periphiral (sp).... Good luck!! R/ Al
Old Jan 19, 2010 | 09:55 PM
Rossi396's Avatar
Rossi396
Ipod2car. Simple install. The cable you use with the actual Peripheral unit will depend on whether or not you have a CD changer. Look at this link:
http://forums.corvetteforum.com/c5-g...ipod2-car.html
Plenty of information here on the forum, including one link here in the Audio section with pics I saw within the last month or so...
Rossi
Old Jan 19, 2010 | 11:58 PM
markcz's Avatar
markcz
ASSUMING YOU HAVE A C5....
If you have a changer in the trunk and don't mind splicing into the cables you can do this mod. If you can install the relay, it's not hard to power the switch feeding the relay from the radio's existing 'amp turn on' circuit so it isn't always energized.
Old Jan 20, 2010 | 03:31 PM
happa's Avatar
happa
Thanks everyone, I had already took out my CD charger a while back. o'well, I will look into all the info y'all supplied me with!
Old Jan 20, 2010 | 09:19 PM
vett79's Avatar
vett79
Dumb question My '98 C5 has no rear CD changer...are the wires back there for all C5s?
Old Jan 21, 2010 | 07:15 PM
markcz's Avatar
markcz
The wires in the trunk wouldn't be there, but 99% of C5's have the needed wires in the passenger floorboard area. You can buy gizmos that connect to the two connectors on the floor, or buy a COR-HAR which would have the same plug as a changer equipped car.
Old Jan 21, 2010 | 07:42 PM
vett79's Avatar
vett79
Thanks.......I'll check it out when it gets a little warmer.
Old Jan 22, 2010 | 11:27 PM
Slider-01's Avatar
Slider-01
I just did mine in my 97. Some of the cars do have the connectors in the passenger area as stated above.
In mine it was simple, basically unplug the connector from the back of the stock head unit, plug in the new harness, the stock plug into the harness and the other end of the harness into the interface. run the wire from behind the radio to where ever you want your iPOD. I put mine in the console.
I bought the wiring harness and interface from Dennis at DD Mods. Took me 30 min to remove the console, bezel, and radio. Works great with my iPOD Touch.
do a search and you should be able to find what you need.
Good luck,
Old Jan 23, 2010 | 01:34 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
here is your answer
2 options for you to select from to have a true plug n play setup for your itouch
http://forums.corvetteforum.com/c5-g...r-99-99-a.html
To IPod Touch??
