Audio for Dummies (me) - I need some advice!
I have a 2010 stock C6 coupe with the base radio/CD. No Bose. No 6 CD player. I am going to install the Kenwood DNX-9140.
Should I upgrade the speakers or are the stock ones OK? Would upgrading the speakers improve the sound quality noticeably? If I did change the speakers, I assume I would need to replace the ones in the doors and the ones in the back. Is that correct? What are some decent speakers I should consider?
Would/Should I run new speaker wires?
Also, should I add an aftermarket amplifier? Any suggestions on what kind?
Basically, I am upgrading to the Kenwood DNX-9140 and would like to have a "good" sounding system without having to spend too much over the $1700 or so that the DNX-9140 head unit and peripherals will set me back.
I am not a big audiophile, I just want a "GOOD system". Where should I spend my $$$ to give me the best return?
So far I have ordered:
Metra 95-3304.................Received
Metra 40-GM10................Received
PAC SWI-JACK.................Received
2 ground loop isolaters.......Received
GMAHCM.........................Received
GMAH24..........................Received
KCA-IP301V.....................Received
Kenwood DNX-9140 ..........Received
Any advice/suggestions/comments are welcome.
Thanks, Randy
Metra 95-3304
Metra 40-GM10
PAC SWI-JACk
GMAHCM
GMAH24
KCA-IP301V
Kenwood DNX-9140
Thanks, Randy
Say: Amp: Arc Audio KS 300.4 $350 ????......listed in a previous thread
ANY Recommendations?
I would like to keep additional cost under $1000 if possible. Like I said I am not an audiophile looking for a top of the line system, just something better than stock.
Thanks!
Are you planning on adding a sub in the trunk? If you remove the OEM door subs you pretty much have to in order to call the final product "good".
If you want to keep the rear speakers, and add a sub, you could do....
Alpine PDX-5 amp - $400
Polk MM6501 components for the front - $200
Mid-grade 5.25" in the back - $100
Sub box for rear cubby - $300
Skip the rear speakers, get a 4-channel amp and bridge 3/4 to a sub, the price goes down a few hundred.
My setup is in my sig link, everything other than the radio (amp/speakers/sub/DIY Box) only cost me $500.
The possibilities are endless
Well, I wasn't planning to add a sub. I didn't know that the door speakers had subs integrated into them.
I told you that I was 'uninformed'.
Replacing the HU alone will give you some improvement in sound quality.
Of course you won't be using the full capability of the unit, but it's not worth spending another $600+ on a set of components and amp if you're not used to appreciating the sound quality.
Also, once you start to listen to some SQ setups, you'll be hooked and there's no going back. It's a very expensive hobby.
In short, if you're not a huge music/audio person, I'd say just stick with your stock speakers.
Just my $0.02
Dan
Just my $0.02
Dan
I was wondering if the added expense would be worth it.
Besides that, I just spent some $$$ on DSV's steering wheel that the have a weekend special on.
If you don't mind taking apart the center console again, I think it's a good idea to get the HU first and see if you're satisfied enough with the sound.
IF you think you want better sound, I'd recommend a set of components for the front($100~$200 range), and a 4 channel amp(2 channels for the front, 2 channels for a sub) + a stealthbox(can be had for around $400 used including a driver... I think..).
Is the added expense worth it? To me, definitely.
But like I said, you should carefully gauge your appreciation in sound quality vs. $$ factor.
While spending $1k on a set of speakers/amp could be worth every single penny to some people doesn't necessarily mean you'll be totally satisfied after spending that much money.
It would be ideal if you can get a chance to listen to an aftermarket setup in a Vette and see if you like it.
Good luck!
Dan
Good luck!
Dan
How would the Boston Acoustics S35 compare to the Infinity Reference 3022cf ?
Any idea? Thanks!
post up what you do
Tim
post up what you do
Tim
Along with the previous Kenwood DNX-9140 and peripherals mentioned earlier I also ordered the following equipment with the help of Pentavolvo's advice.
AMP.............................Alpine PDX-4.100....................$273.00 shipped
Component Speakers.......Elemental Designs Edi e3.65i.....$150.00 shipped
Shallow subwoofer...........Pioneer TSSW2501S4...............$90.00 shipped
Amp wiring kit..................................... .......................$35.00 Shipped
Car Audio for Dummies (the book!)...........priceless
What do you think?..........Do you think I can get a pretty good sound from this combination if I set it up right?
I have yet to get a box for the AMP.
Randy
PS: It's a little intimidating, cross-overs and such but I'll learn.
Randy
Learning stuffs will take a while, but nothing to be too intimidated about.
Once you listen to a well-tuned/installed system, you'll understand why people spend so much $$ into audio systems.
Make sure you know what you're getting into before you actually do.
Good luck!!
Dan
http://www.sonicelectronix.com/item_...ik+KIT-4G.html
I know I will probably need a few more things but not sure of what else I need.
I'm just waiting to receive everything, then I'll take stock and see what I am missing.
I still need to get (or build) a sub box.
I ordered two 12x12 1/4" sheets of LEXAN for my speaker mounts.
Pentavolvo, if you know of anything else that I am sure to need, please let me know.
Thanks, Randy
