Sponsored by: Innova
Blose on non Blose?
Old Feb 8, 2010 | 09:39 AM
P51tj's Avatar
P51tj
Default Blose on non Blose?
After searching and reading I'm still not sure if in an 09 coupe with nav and 7 speakers is a Blose unit or not. Sounds like it . Would/could someone please offer their expert response to this. I want to keep the h/u with the interface to the hud and all, so I'm just looking to upgrade the speaks and add an amp and sub. Thanks in advance for any and all info.
TJ
Old Feb 8, 2010 | 09:58 AM
rcmigpilot's Avatar
rcmigpilot
TJ
Nav is Bose. Look for a small Bose badge on the speaker grill to confirm. The C6 audio FAQ shows how to wire the stock head with aftermarket amps and speakers.
Old Feb 8, 2010 | 10:05 AM
SilverSurferC6's Avatar
SilverSurferC6
Don't do it I ended ripping out all my BLOSE and what a difference!
Old Feb 8, 2010 | 05:00 PM
P51tj's Avatar
P51tj
Duhhh, well that should get me the Darwin award for the day!!! Thanks for the input.
Old Feb 8, 2010 | 05:43 PM
markcz's Avatar
markcz
All you need is the ADD-GM24 and whatever new equipment you want to install.
This thread shows how to use the addgm24, then all you need to do is tap the B3 pin as your remote trigger supply.
To Blose on non Blose?
