Sponsored by: Innova
Anyone replace sub in 08 non-bose?
Old Feb 24, 2010 | 06:02 AM
C6XTACY's Avatar
C6XTACY
Default Anyone replace sub in 08 non-bose?
If so, what kind did you go with? Somehow, I blew the one in the passenger door.
Old Feb 24, 2010 | 06:56 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
pretty much need to get another c6 non bose door woofer unless u plan on doing major work
Old Feb 24, 2010 | 09:25 AM
C6XTACY's Avatar
C6XTACY
Great.....But thank you for the heads up.
Old Feb 24, 2010 | 11:08 AM
SilverSurferC6's Avatar
SilverSurferC6
I have two Bose type dor sub with the twiddler thingies. Let me know if you're interested.
Old Feb 24, 2010 | 05:01 PM
C6XTACY's Avatar
C6XTACY
Thanks, but my car is non-bose. If I'm not mistaken your "sub" is larger than mine.
Old Feb 24, 2010 | 05:13 PM
pentavolvo's Avatar
pentavolvo
correct, u need a nonbose sub
Old Feb 25, 2010 | 05:03 AM
C6XTACY's Avatar
C6XTACY
Strange. I was heading in to work tonight. As I was doing so, I hit a little dip in the road and the bass came back to that speaker-momentarily. Seems to be a connector issue. While I'm changing my brakes/rotors this weekend, I might as well take the door panel off and have a little look see.
Really too bad there is no simple way to replace the stock "sub".
Old Feb 25, 2010 | 07:11 AM
pentavolvo's Avatar
pentavolvo
to put an aftermarket door sub in you would have to sound deaden the **** out of the door, build a mounting plate, add an amp, wiring, etc
its kind of a slipery slope because at that point you might as well do the entire stereo
Old Feb 25, 2010 | 08:26 PM
C6XTACY's Avatar
C6XTACY
Ah I see. I might as well just get a JL stealth box and save the hassle. Thank you.
Old Mar 6, 2010 | 03:51 PM
C6XTACY's Avatar
C6XTACY
Finally got the door off. The connection is fine, but the sub only works if I push on it
So yeah, I need a new one. Anyone know where cause I sure as hell can't find one.
Old Mar 6, 2010 | 05:21 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
I will be redoing my car and replacing my non-bose speakers with components. I'll be happy to send you my non-bose door speakers once I do mine. (You pay the shipping charges) Also adding an amp, HU, and sub-woofer.
The only problem is it might be a several weeks before I tackle it because I am taking everything out (seats, carpet, etc.) and installing sound and heat insulation and I will need to take some time off work to do it.
If you can't find one before then I can help you out. Randy
OH yes, mine is a 2010.
Old Mar 6, 2010 | 05:29 PM
C6XTACY's Avatar
C6XTACY
Thanks Randy. However, I just found a place like 10 minutes ago. But if someone in the future will need one and can't fine a place, go to www.corvetterecycling.com. It only cost me 32$ shipped
Old Mar 6, 2010 | 05:34 PM
ncvette_1FUNRIDE
No problem. I forgot about that place. Glad you got what you needed.
To Anyone replace sub in 08 non-bose?
