Sponsored by: Innova
C5 Headunit Installation
Old Mar 10, 2010 | 09:22 PM
Mickman's Avatar
Mickman
Default C5 Headunit Installation
I am going to be putting an Alpine CDA-9886 in a 2004 Z06.
( http://signature.crutchfield.com/S-Y...-CDA-9886.html )
From what I have read here on the forum I need:
dash kit (already have)
antenna adaptor (already have)
GMCRV2 harness - http://www.discountcarstereo.com/detail.aspx?ID=378
if I want to retain the ability for the head unit to stay on after I turn off the car, a GMRAP module - http://www.discountcarstereo.com/detail.aspx?ID=1349
Is this correct? Is the GMCRV2 the best harness I can use?
Also, where is the cheapest place to buy the harness online?
Thanks in advance guys,
Mick
Old Mar 10, 2010 | 10:23 PM
markcz's Avatar
markcz
If you use a Metra XSVI-2004 instead of the GMCRV2 you won't need the GMRAP. Do your own search, but Crutchfield may actually be the best price of the places that have it in stock
Other than that, if you're keeping the stock speaker setup, your list looks complete.
Old Mar 10, 2010 | 11:39 PM
Mickman's Avatar
Mickman
Thanks for the reply!
I don't see anything mentioned about the door chimes and such, has anyone used this harness before?
If theres anyone that has used either,
I'd like to have some pros/cons of this , and the GMRAP + GMCRV2.
Old Mar 11, 2010 | 06:49 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
door chimes are not an issue on a c5
gmrap + gmcrv2 will work. personally i would forget about rap
Old Mar 15, 2010 | 07:15 PM
tonylukes3's Avatar
tonylukes3
Looks good, I actually had that unit installed recently before returning it for another. Can't speak for the GMRAP, but I have the Metra and it was a very simple install with no issues
Old Mar 16, 2010 | 08:11 AM
Paul 75 L82's Avatar
Paul 75 L82
Tony, how do you like the Kenwood?
Old Mar 16, 2010 | 01:41 PM
tonylukes3's Avatar
tonylukes3
So far it looks great! I just got it installed last night after running all the cables for a 2-channel amp, so by 1am I didn't feel like putting the dash back together lol. But from the brief radio test I did, it sounded nice!
Old Apr 7, 2010 | 09:45 PM
daveshea's Avatar
daveshea
Default Removing stock bracket behind factory C5 radio for aftermarket install
I am getting ready to install my aftermarket radio in my C5, and see that we have a metal bracket behind the radio that is in the way. I know I have to remove part of that.
Do I just need to remove the circular part that comes up from the bottom, and what sort of tool can I use to cut that off?I don't think I can fit a dremel in there to cut that part of the stock bracket off.
Looking forward to any suggestions for revmoving that rear support bracket piece.
-David
Old Apr 7, 2010 | 09:54 PM
pentavolvo's Avatar
pentavolvo
hacksaw blade works well, some have used a big screwdriver and bent it back. you need to cut at about the halfway point of that hole or a bit lower
Old Apr 21, 2010 | 09:37 PM
TP C5's Avatar
TP C5
-David
FYI: I used a dremel when I took mine out. Very simple and clean!!
To C5 Headunit Installation
