Sponsored by: Innova
powered antenna
Old Apr 7, 2010 | 08:30 PM
bowtiebubba's Avatar
bowtiebubba
Default powered antenna
Im installing a pioneer 910 bt. Do i need to connect the powered antenna wire from the new headunit if i dont have a power antenna?
Old Apr 7, 2010 | 09:25 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
deff gonna wanna read through the c5 faq on how to add a voltage regulator for the in glass antenna in ur coupe
im currently workin in moberly this week and most likely next week, im willing to lend u a hand if need be let me know
Old Apr 7, 2010 | 10:03 PM
bowtiebubba
I would love to have your help.I wish i knew you were in the area,i would of gladly paid you to do the wiring. My problem is i have to have the car done by saturday morning. We are entered in the corvette cup car show this weekend in columbia,mo
I think the wire says antenna control. I thought it was for a power antenna which the coupe doesnt have.
Old Apr 7, 2010 | 10:21 PM
pentavolvo's Avatar
pentavolvo
correct but coupe down have an antenna ampifier. pm me ur number i can give u a call tomorrow if u want. honestly unless i get stuck late at work i could come by tomorrow nite if want or need a hand with that or wiring as long as u have tools
Old Apr 7, 2010 | 11:01 PM
markcz's Avatar
markcz
Just connecting the antenna is sometimes enough. Powering the 12v wire (already done if you're still using stock door subs) helps some, adding the 5v makes it a bit better for most.
http://forums.corvetteforum.com/audi...ml?forum_id=20
Old Apr 8, 2010 | 01:13 PM
bowtiebubba
PM sent.
To powered antenna
