Sponsored by: Innova
Problems using Metra Bose interface
Old Apr 9, 2010 | 11:20 AM
daveshea's Avatar
daveshea
Default Problems using Metra Bose interface
I installed my JVC headunit yesterday using the Metra Bose interface sold by Crutchfield. I have two problems:
#1: The radio stays on all the time, unless I deliberately turn it off. When turing off the ignition or opening the door, the radio stays on. I thought the Metra device was supposed to supply the necessary switched power wire?
#2: The red light does not illuminate on the Metra device, and the door subs are not turning on. The other speakers seem to work use fine.
What is going on there?
Is the unit defective, or is there wiring issues? I simply installed the device using the very sparse Metra instructions included with the unit.
Thanks for any help you all can provide!
-David
Old Apr 9, 2010 | 11:54 AM
bigmatt22's Avatar
bigmatt22
Navigator
I just installed mine as well and I am having the same problems...the only thing i could possibly think is that the wiring diagram is wrong or something is screwed up with the units themselves (which hopefully its just wiring). I am going to try and connect the power directly to the accessory wire off the ignition when i get a chance this weekend and see if that helps the issue, but any other help would be greatly appreciated!
Old Apr 9, 2010 | 12:04 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Look at the instructions carefully and you'll see why I recommend the Peripheral-now-PAC modules. It requires you go to Radio Shack and buy a 12V relay and wire it in. There is not switched 12V power in the factory harness so the module has to read the data bus and create it using a relay. The instructions are there, you just have to know that it is required
This is assuming you guys are talking about C6.
Old Apr 9, 2010 | 12:05 PM
Vegas Vette's Avatar
Vegas Vette
-David
The Merta interface has whats called the RAP (Retained Acc Power) the head unit will stay on until the one of the doors is opened. As for the subs for the Bose you need to hook the head unit remote power (the wire that would power up your amps) connect it to the blue wire in the interface control box then your door sub will work.
If you do not want to use the RAP feature them use a 12V ignition power for the head unit and it will come on and off with the ignition key.
Hope this help you some.
Old Apr 9, 2010 | 12:09 PM
bigmatt22's Avatar
bigmatt22
Navigator
Thanks I know I did not plug the blue wire into my interface so I will give that a shot when I get home! But yeah the power issue I am not sure what is up with that it may be related but i doubt it, I will probably tie into the switch if all else fails. Thanks for the help!
Old Apr 9, 2010 | 12:12 PM
daveshea's Avatar
daveshea
I understand the RAP feature, but please note that my radio is staying on regardless of opening the door or not - if I don't turn the power off at the radio, it will stay on forever.
I have the power antenna/remote wire hooked up correctly, but some posts on here suggest the need to connect that to a different wire in the factory harness in order to turn the bose system on? Anyone know about this?
Also, if I want to get a switched power signal, where can I get this? You mentioned a wire under the ignition? What color and where? Any other sources?
Old Apr 9, 2010 | 01:17 PM
Vegas Vette
Yes after I posted I reread your thread I jump 12V Acc power from the passenger foot well there is a plug down there with three wires going to it 12V constant, 12V Acc and ground you can get you power source form there and the head unit will work fine.
As for powering the Bose subs blue to blue connection should work it always has for me.
maybe some one else has some insight on this issue.
Old Apr 9, 2010 | 05:50 PM
markcz's Avatar
markcz
In C5 the blue/white 'remote' wire from the HU needs to be connected to the dark green wire at pin 8 of the black plug in order to turn on the door subs.
In C6 the blue/white 'remote' wire from the HU needs to be connected to the white wire at pin B3 of the big plug in order to power up the stock amp.
Do not use the solid blue wire coming out of the HU, it's only powered when you're listening to the radio, use the blue/white wire.
The red, yellow, and black wires from the interface need to be connected to the same wires on the HU. It will listen in on the cars data wire and control the 'switched' power with the RAP feature.
If you have everything connected as above, the interface may be bad (if it won't power down), or you may just need to use a relay as the instructions probably show (if it won't power up).
Old Apr 9, 2010 | 09:37 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
knowing what car this is would help alot
Old Apr 9, 2010 | 11:26 PM
daveshea's Avatar
daveshea
Car involved is a 2000 Convertible.
Old Apr 13, 2010 | 09:28 AM
Mickman's Avatar
Mickman
I'm about to install my alpine cda 9886 in the next month or so using the Metra harness...
I just wanted to know if you ended up fixing your problem, so that way if I run into the same problem I know how to deal with it.
Old Apr 13, 2010 | 10:15 AM
daveshea's Avatar
daveshea
I gave up on the product - I had everything correctly connected according to the directions.
I decided to replace the stock speakers with better ones, eliminating the need for the harness.
Disappointing, but a good result in the end.
-David
Old Apr 13, 2010 | 12:31 PM
Mickman's Avatar
Mickman
Thats disappointing, I hope that doesn't happen to me.
I've heard lots of other guys using the Metra harness with no problems, but now I'm hearing of situations like this!
Old Apr 17, 2010 | 11:15 PM
birdy's Avatar
birdy
6th Gear
I've just installed an Alpine unit in my '93 with a Metra harness supplied by Crutchfield and after turning it on for the first time the tuner did not work at all. This was due to an open circuit on the antenna cable from Metra (no continuity on the center conductor). Crutchfield replaced the harness quick enough, but running the cables from the rear deck to under the dash once was enough! My advice would be to check continuity of all the wires in the Metra Harness before you install it. Other than that it worked fine. Great unit.
Old May 2, 2010 | 12:11 PM
Mickman's Avatar
Mickman
I installed my headunit this week using the Metra harness and had no problems. The installation was pretty much plug and play, had no problems with the wiring.. and everything works great!
Old May 2, 2010 | 09:19 PM
wit2pz's Avatar
wit2pz
I installed my JVC HU yesterday as well, and used a ton of notes from the FAQ sticky. I did not use any interface, but got the factory speakers working thru the factory amps.
To answer the question about where to get a 12v switched source, if you remove the driver side knee bolster, there is a cluster of wires that run up almost directly behind the ignition switch. The fat brown wire is the 12v switched power. I stripped just enough of the sheath back to wrap my 12v switched HU wire around it, then soldered it in place.
It's good enough until I get my amp, sub, and component speakers ordered and shipped to me.
To Problems using Metra Bose interface
