Sponsored by: Innova
Qi45 laser shifter
Old Apr 11, 2010 | 01:45 AM
baxterboy's Avatar
baxterboy
Default Qi45 laser shifter
My first impressions with this system is not good. Seems like when you are on auto it will pick up everything around you so you are forced to turn it off. It is also real late to pick anything up. Where they get this long range is a myth. Lucky if it is half a block. Also have a problem with the laser shifters. When I am hard on the throttle the laser shifting sequence goes of and goes crazy. Really just a piece of garbage all the way around.
