Sponsored by: Innova
C5 audio system questions
Old Apr 13, 2010 | 08:06 PM
KenShores's Avatar
KenShores
Default C5 audio system questions
I had the door panels off this weekend and got me to wondering about speaker replacements. I've been reading the sticky on the C5 system and have some questions.
If I understand things correctly, the signal leaves the HU and goes to the Bose processor unit (BPU) and back to the HU (through a PA), then back out to the speakers. The front speakers now take these signals from the HU and are applied to twittlers and a local PA at the woofer.
So is this an amplified signal going to the local PA at the woofer? If I were to replace the front sets, would I need a new local PA to drive the new speaker replacing the woofer?
Old Apr 13, 2010 | 08:26 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
local PA????
Old Apr 13, 2010 | 09:57 PM
KenShores's Avatar
KenShores
Yes, Local to the woofer speaker under the tweeter speaker. The schematics show this as an amplifier. PA=power amp.
I think I had read that also in the sticky. The schematics in the sticky show this. Any help out there???
Old Apr 13, 2010 | 11:31 PM
markcz's Avatar
markcz
The signal going IN to the door subs is line-level, it comes directly from the bose processor. The wires you can see on top of the big speakers have the already amplified speaker-level signals.
What exactly are you trying to do? Replacing the oem door subs with something else that's still in the doors is just a bad idea. Putting a real sub in the back with an external amplifier is the way to go.
What most do (and what gives you the best bang-for-your-buck) is install a 6.5" component set in the doors, then add a sub in the trunk. The center tub in C5 is perfect for a 10" aftermarket sub.
Old Apr 14, 2010 | 12:43 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by markcz
the center tub in c5 is perfect for a 10" aftermarket sub.
12"
Old Apr 14, 2010 | 10:04 AM
KenShores's Avatar
KenShores
Yes replacing the original set with a 6.5 component set. If I do this then do I just take the wiring from the twittlers and connect to the xover for the new set? Do I just disregard the lines that go to the sub-woofer from the BPU?
I keep too much stuff in the tub - no boom boom speaker for me.
Old Apr 14, 2010 | 05:54 PM
markcz's Avatar
markcz
If you are certain that you won't be adding a sub in the back you may want to consider keeping the door subs. Without either there will be a serious lack of bass.
If you do install components you'll need a new amp to properly power them, so just run new wires.
If you keep the door subs you can replace the 3.5" twiddlers with any 4 ohm 2-way for a pretty good improvement. Polk db351 and Boston Acoustic S35 are popular choices.
Old Apr 14, 2010 | 06:19 PM
KenShores's Avatar
KenShores
Thanks, for the info. I must have made a mistake of the path (BPU) to the subs , but it looked as if the subs did have a local PA to me. This was concerning me. So I think until I decide to get a different HU, I may as well stay with the stock front speaker assy. I'll replace the rears with a coax 5.25 set and see if things sound a little better. Thanks again for your input.
Old Apr 14, 2010 | 08:21 PM
markcz's Avatar
markcz
They do
I think you'd get better results replacing the front 3.5's
Old Apr 14, 2010 | 09:34 PM
vett79's Avatar
vett79
Definitely only need to do the 3 1/2 fronts. I just did all 4 twiddlers with Polks. The Polk DB351 speakers made a nice improvement for not much money. I won't say the DB651 speakers in the back were a waste but close to it. Not much sound comes out back there.
Good Luck!
Old Apr 14, 2010 | 10:28 PM
KenShores's Avatar
KenShores
Good Luck!
Really??? I was thinking that I would get an improvement in replacing the rear speakers. I like to adjust the fade to get more out of the back. I have a vert, and I perfer the sound comming from the back. I sure I could give it a try. I'm thinking a $50 set, some where about there.
If the twiddler replacemnt is an improvement I may try that too. Twiddlers (twittlers), makes me think of the Monty Python skit of the Twit Olympics.
Hey thanks for the info and opinions. I'm not really looking for the "super system" just improvements. Keep them coming if you like.
Old Apr 14, 2010 | 10:34 PM
pentavolvo's Avatar
pentavolvo
u really prefer sound coming from the rear???
maybe ur fronts are just beyond shot.
Old Apr 14, 2010 | 11:25 PM
KenShores's Avatar
KenShores
No they are not shot, I like them. I had the drivers side door panel off last weekend and looked at them. The small speaker did not impress me much, looking at it. Then I noticed all the junk under it, so it got me looking at schematics on the system.
I guess liking the sound coming from the back/rear is the old fart thing in me. All my old days cars, we would modify (even add a speaker) on the back deck. I'm talking the days of AM only and 8 tracks, 6x9's old stuff. I guess I just got used to liking the music coming from the back. Of course I like suround sound and new $*it, but a balance more from the back is what I like. I'm not talking just boom boom, highs and lows too. Call me crazy if you wish. Newer is better.
To C5 audio system questions
