Sponsored by: Innova
NAv Experts Step Inside
Old May 5, 2010 | 11:15 AM
vettn71's Avatar
vettn71
Default NAv Experts Step Inside
I've drawn the schematic for my Kenwood DNX, Scoshe GM11 interface and car harness. Please forgive the quality; I drew this in my hotel room using a ball point pen and a pad of paper for a ruler. If someone would like to do this professionally, please do.
Please review this and see if there any mistakes. I haven't seen anyone put the three together and I hope to have something everyone one can use. I doubt that there's much difference between NAV unit wiring, so this should be helpful to anyone installing a NAV
Jim
Old May 8, 2010 | 08:14 AM
vettn71's Avatar
vettn71
I thought all the NAV gurus hung out here. No one wants to take a stab at this? I think for those of us less knowledgeable it would be of great benefit. This would apply to most NAV units, from what I can see and the interfaces. Come on, guys and girls, weigh in
Jim
Old May 8, 2010 | 08:38 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Here's the thing, Jim, you're over-thinking it. The wiring is the same for EVERY stereo in C6 and your setup is almost specific to the Scosche module(inclusion of relay), that very few people use (Peripheral GMCO is my personal choice, they've now been bought up by PAC and I think the OS2 is the unit). The units all come with wiring diagrams and you just match 'em up, usually by wire color.
So basically what I'm saying is that those of us with tons of experience know that it's not worth the time it would take to unravel your diagram (with REALLY dark graph lines on the scan making it very hard to see) when this is really common, easy stuff.
Please don't take offense. I know you're just trying to get the job done right, but that's just how it is...
Old May 8, 2010 | 10:17 AM
markcz's Avatar
markcz
100%
Without a link to online instructions for the GM11 (which I can't seem to find), how are we supposed to know how that thing works
It doesn't matter if your car is Bose or non-Bose, if you're keeping the stock amp/speaker setup, you need to supply the oem harness with the line-level signal that comes out of the RCA plugs from the new HU. The only reason I mentioned that is because my brief search did show that a GM11B exists, that may be the one you need. If your instructions have an option for bose or 'premium' bose, use the normal bose instructions on ALL C6 (both bose and non).
Anything other than power and audio is NOT present in the oem harness. For illumination/speed sensor/backup/whatever you need to connect in other locations of the car. Just because the interface has an orange/white wire in it, that doesn't mean it will function properly in a C6.
This thread shows 90% of what you need to do, plus more. The only thing it doesn't have is the fact that the gray wire at the TC/AH button is where most people connect the illumination wire. One thing to check on first, some aftermarket units need a 12v signal to come on to indicate the interior lights are on, which then dims the display for night time driving, some use a true dimmer control input with a varied voltage, the gray TC/AH wire is a true dimmer wire.
If you have any specific questions, feel free to ask away, but even after I flipped it over to read the writing that drawing was still way to hard to follow
Old May 9, 2010 | 08:59 AM
vettn71's Avatar
vettn71
Believe me, I'm not offended. Been years since I've done any drafting, and I realize how rough it looks. I guess I'm over-thinking things becuase in following the several posts in this forum I still am not certain what I need to do to install the Kenwood DNX 7100. I've changed out the Scosche interface with a Perephrial GMCO, since that seems to be the one recommended. When I went to Scosche's website they no longer listed the GM11, so I didn't think it was a good bet.
My remaining questions:
1) I'm using the stock amp and speakers. I assume the blue/white from the interface harness supplies the power to turn on the amp (P. CONT) through the radio harness
2) There has been a lot of back-and-forth concerning the need for a 5V to 8V signal for the antenna. Some say they've used it and it helps, some say it works better without. That is confusing.
3) Does the Kenwood require 12V for illumination or a true dimmer wire. Where can I pick up the TC/AH grey wire for illumination if I need a true dimmer?
I appreciate the repsonses. They may have saved me from installing this with the incorrect interface.
Jim
Old May 9, 2010 | 01:56 PM
markcz's Avatar
markcz
1. correct, blue/white from HU to blue on gmco
2. forget about the 5v, since you're using stock amp you already have 12v applied to module, if reception is bad worry about it later
3. don't know, it should say in instructions that came with unit, or try a kenwood forum
GMCO is easy to install... Red-yellow-black match to HU wires, plug in RCA's, blue/white from HU to blue on gmco. That's it. All of the other wires from the HU need to be connected directly to the car in other locations.
If you're installing a steering wheel button interface, the purple wire at A6 needs 12v supplied to it, and the dark blue wire at A7 is the one that gives the button signal to your SWI gizmo. Unless you move the orange wires in the gmco harness, you need to splice into the radio harness.
All of the other wires are shown in the link in my last post.
If you need them, C6 schematics are all HERE
Happy modding
Old May 9, 2010 | 10:41 PM
vettn71's Avatar
vettn71
Thanks for the help
Where can I pick up the TC/AH wire?
Jim
Old May 10, 2010 | 12:05 AM
markcz's Avatar
markcz
It's the gray wire under the button on the center console.
Old May 10, 2010 | 02:24 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Thanks for understanding my point and not turning it into a typical forum-bash.
Mark's dead on in his advice. That wire can be a little tough to ID in the harness as its close to another color that's there, but it's definitely gray and if you don't second-guess yourself on the color you'll get it first time.
Old May 10, 2010 | 08:11 PM
vettn71's Avatar
vettn71
Thanks to all who responded. This is my first NAv install, so I don't want to nuke it
Jim
To NAv Experts Step Inside
