Sponsored by: Innova
Tweeter location question.
Old May 11, 2010 | 03:50 AM
kennya35's Avatar
kennya35
Default Tweeter location question.
When I get home from my deployment, I am installing a whole new audio system. One question I have is where is the optimum tweeter location, behind the door pulls or down in the door with the mid bass driver? Those are the only two locations I am looking at, not messing with the a-piller.
Old May 11, 2010 | 10:54 AM
Kale's Avatar
Kale
Originally Posted by kennya35
When I get home from my deployment, I am installing a whole new audio system. One question I have is where is the optimum tweeter location, behind the door pulls or down in the door with the mid bass driver? Those are the only two locations I am looking at, not messing with the a-pillar.
Both are pretty bad, but for different reasons.
Behind the door pull you're going to get all kinds of nasty reflections and other sound problems just because the tweeter is sitting in a dish behind a door handle. On top of that, the tweeter ends up being much closer to you than the woofer. On top of that, the dish situation mentioned before will cause strong side bias.
Next to the woofer is, generally, a good position. In this car you will end up with side bias and lost frequency response. On top of that, your leg is going to block it unless you're 4'11 and skinny.
I would also base my tweeter choice on your desired install location. If you insist on using the door handle, find a set that has a high cutoff between woofer and tweeter. (Say, tweeter plays above 4k only.)
Old May 11, 2010 | 04:39 PM
Lancejoker's Avatar
Lancejoker
You're really limiting the quality of sound you can produce by completely ruling out the A pillar locations.
Old May 11, 2010 | 05:40 PM
slief's Avatar
slief
I was in the same situation. I am getting ready to install a stereo in my 09 Z06. I decided on the A pillar but instead of destroying my original trim, I found a used pair of pillar trims on ebay for $60. My plan is to remove the vinyl from those and fabricate tweeter mounts on those and recover them with matching vinyl.
That said, many tweeters include surface mount bezzels which could be easily modified to mount to the surface of the pillar cover. There are also some really small and thin tweeters on the market that can be installed into the pillar without making a mount. The down side to that approach would be the quality of the tweeter.
While it may be a pain to do the pillar mount, if you are going through the trouble and expense to install a sound system, the additional expense or labor to install the tweets in the pillar would be well worth the effort in my opinion and experience.
Do it right the first time or you might end up kicking yourself in the rear down the line..
Old May 11, 2010 | 09:04 PM
Patches's Avatar
Patches
I installed a completely new system in the wife's C5 a few months ago and have been PM'ing with another member who offered to mold the tweeters in the A-pillars but suddenly got very busy so I'm looking for someone else who can do the project. I had some time this weekend and played with the tweeter A-pillar mount. I settled on the position in the pic below. I went ahead and cut crude holes in the pillars and pressed the tweeters into them so the wife wouldn't have to drive around with the tweets hanging on for dear life. It sounds ten times better than with them in the door. The wife was thrilled with the change as she was complaining about how muffled they sounded in the doors mounted right next to the mids.
They definitely need to be molded in as there is not enough room in the pillar behind them - they are pushed up against the metal post in the pillar. I have an extra set of A-pillars I bought used to send for the molding job once I find someone who can do this.
Old May 12, 2010 | 01:36 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I wonder if Double "D" (aka Dennis) would do this ?
Old May 12, 2010 | 05:22 AM
kennya35's Avatar
kennya35
Thanks for all the responses! I just really hate to screw with the A-pillars and changing the look of the car. Keeping it stock looking is a hanging point with me. Plus, the big reason is that I wont be able to afford having someone mod my a-pillars. I am spending enough on the system. Who knows though, maybe one of these days I can get it done! Thanks all!
Old May 13, 2010 | 09:11 PM
Lancejoker's Avatar
Lancejoker
Was supposed to do it for me. Then he got busy and I haven't heard from him in maybe two months.
I'm sure he didn't mean for it to happen,but it happened none the less.
Old May 14, 2010 | 09:55 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I'm sure he just lost it in the shuffle, happens to the best of us.
Old May 16, 2010 | 03:20 PM
Jack Daniels's Avatar
Jack Daniels
Is there not a way to attach the tweeters on the surface of the A-piller without cutting into it, other than maybe one small hole for the wires?
Old May 16, 2010 | 03:48 PM
Patches's Avatar
Patches
Sure but it would not look factory or well-integrated. Check out this other recent tweeter thread.
http://forums.corvetteforum.com/audi...lars-help.html
To Tweeter location question.
