Sponsored by: Innova
Aftermarket Head Unit Install Using Adapter Questions.
Old Mar 19, 2002 | 02:49 PM
Bradley33's Avatar
Bradley33
Default Aftermarket Head Unit Install Using Adapter Questions.
I want to install an aftermarket stereo and for ease of installation I'm going to use the adapter that allows integration with Bose (although I will probably replace the speakers) I just need a harness that will allow me to easily wire the radio so it will plug into my car and I DON'T want to tear apart my interior!
Is this a decent way of doing this or am I way off track?
Also I know that the radio in my '92 is in some weird place.... do I have to track it down and remove it?
Finally I've heard that some people set off their check engine light with aftermarket installs. Will I have a problem with this?
Thanks a TON for all the help (past, present and future)!!!
Old Mar 20, 2002 | 12:37 AM
Dave84/76's Avatar
Dave84/76
Default Re: Aftermarket Head Unit Install Using Adapter Questions. (Bradley33)
Bradley, the radio in the 90-92 is located under the passenger side dash (behind fuse block). You do not have to remove it, but you will have to get to the wires and the antenna lead. You will need an antenna adapter. As far as the system light, see this post: http://forums.corvetteforum.com/zerothread?id=260041
Old Mar 20, 2002 | 11:28 AM
Bradley33's Avatar
Bradley33
Default Re: Aftermarket Head Unit Install Using Adapter Questions. (Dave84/76)
what kind of antenea adapter do I need, and where can I get one.
also do you have any suggestions on getting to my stereo?
Old Mar 21, 2002 | 11:53 PM
Dave84/76's Avatar
Dave84/76
The antenna adapter can be picked up at any stereo shop. GM has used a different size antenna fitting since around 88.
To Aftermarket Head Unit Install Using Adapter Questions.
