Sponsored by: Innova
Starting My Complete Audio Makeover Today!
Old Jul 2, 2010 | 09:28 AM
Gitusum's Avatar
Gitusum
Default Starting My Complete Audio Makeover Today!
Well I am going to start tearing my C5 apart today to start deadening 1st for my complete audio makeover although I do not have all the gear yet But its going to be alot of work and should take awhile so by time i get to the parts that need to be done well.... hopefully they will be here I will post pics of the before during and after as I go along So here is a list of what is getting installed and I am off to tearing the interior out of the car hope it goes easy
Audio being installed
Kenwood DNX9960 Nav
DLS Iridium 3 ways
IDQ10
Stealth box (coming from Dennis)
Raamat Complete door kit
pre cut insulation (crazy cowboy)
carbon fiber dd bezel with gauges (also coming from Dennis)
back up camera
arc audio 125.4 mini amp
arc audio 500.1 mini amp
custom fabricated pillars with my DLS Tweeters (Audio One local shop)
I am sure there is more I will add as I think of it Wish Me LUCK!!!!
Rick
Old Jul 2, 2010 | 11:02 AM
slief's Avatar
slief
Kenwood DNX9960 Nav
DLS Iridium 3 ways
IDQ10
back up camera
Rick
One question or comment.. Are you aware that the IDQ sub is larger in diameter than a standard 10" sub. If that is a JL stealthbox, was it modified to accept the IDQ10?
Oh and 'good luck'!
Old Jul 2, 2010 | 11:03 AM
slief's Avatar
slief
Kenwood DNX9960 Nav
DLS Iridium 3 ways
IDQ10
back up camera
Rick
Nice list of components. I think you will be very pleased with the results. Those little Arc Amps pack some serious punch for the buck and their size! I have been pretty impressed with mine so far.
Oh and 'good luck'!
Old Jul 2, 2010 | 11:40 AM
Gitusum's Avatar
Gitusum
Oh and 'good luck'!
yea bro i know and hopefully Dennis knows as well hahaha and thanx I am hoping it will sound nice
Rick
Old Jul 2, 2010 | 01:28 PM
djgcue's Avatar
djgcue
Nice, I just got done installing the Kenwood DNX9960. You should definitely connect the Center Channel speaker to a separate amp channel for some amazing 5.1 Surround Sound.
Only issues I have with the unit is the UI is a little laggy compared to the Pioneer AVIC and you can't hear the touch tone beep sound when connected to the pre-outs for use with external amps.
Old Jul 2, 2010 | 01:49 PM
Gitusum's Avatar
Gitusum
Default UPDATE: Rear Insulation Pics
well a hour and a half later the rear compartment is insulated To my surprise it went rather fast and smooth here are the pics
before:
after:
yes that is my sweat stains on the side of the car
Old Jul 2, 2010 | 05:08 PM
Rossi396's Avatar
Rossi396
"yes that is my sweat stains on the side of the car "
You mean to tell me you didn't cover the rear end of the car with something...!?
Good luck with the install...
Old Jul 2, 2010 | 05:13 PM
Gitusum's Avatar
Gitusum
yes i did cover it with something....... my sweat from my belly i am not that **** about my car that i have to cover the back of it to install insulation cause if my bare skin scratches the car the gm needs to fire all of their painters for letting sweat and a bare stomach scratch the paint
Rick
Old Jul 2, 2010 | 05:47 PM
VerTigo456's Avatar
VerTigo456
St. Jude Donor '08
Looking good...working on doing the same soon myself. good luck!
Old Jul 2, 2010 | 06:50 PM
fej's Avatar
fej
Good list of gear bro, spend some time getting the midbass and mid mounted and angled correctly behind the factory grill to try and minimize the amount of reflections.
Careful with the cowboy kit as well as some of the interior pieces will not want to snap back in correctly because of the added thickness, and make sure you cut the seat tab areas large enough to get the threads you need to get bolted in.
Also try and plan your wiring routes prior to any connection and test fit some interior pieces to make sure nothing will get pinched, and obviously avoid the signal cables near existing power wires. Try and keep your speaker wires 1 continuous length, as there is nothing worse than putting everything back together and realizing your splice/solder is loose and your speaker is cutting in and out. (ask me how I know)
Spend a little money on your RCA's, but don't spend money on speaker wire. Anything 16/18ga will push whatever you need it to, and no need to waste money on monster or the like. It is too bad that Radio Shack carries Monster now, as their in house brand I used for years and have pushed thousands of watts for me without issue. Now they doubled their in house brand's price to make Monster look like an affordable "upgrade"
Shoot me a pm when you get into the tuning phase, and I am not familiar with the deck will you be able to run full active or through the passives? That dome does not like much in the way of sub 350hz with any power, which I think is where the passive is at 12db rolloff, a boost to the slope might be able to sneak that down a little and smooth out your midbass/mid transition and keep your vocals mainly in your mid.
With that pillar install I think you will be quite happy man. I know you have been at this for a while, good to see you headed down a good road.
Fej
Old Jul 2, 2010 | 07:48 PM
Gitusum's Avatar
Gitusum
thanx fej i dunno half of what you said but thanx pm me your number and i will give you a call when i am close to finished far as the deck its a nav unit with a 13 band eq and i will be running passive. I already got the speaker wires which i got 3 50ft rolls of 16ga street wire off of a audio forum for like $25 shipped which was enough to do both my cars far as the rca cables i have no idea what i am going with yet but i better figure that out real soon
Rick
Old Jul 3, 2010 | 10:38 AM
Gitusum's Avatar
Gitusum
Default Door Deadening
I also managed to get my doors both done yesterday as well with Rick from Raamat supplying the door kit which worked out great!
before:
after:
Old Jul 3, 2010 | 12:36 PM
Patches's Avatar
Patches
Lookin' good!
Keep the updates coming.
Old Jul 3, 2010 | 01:40 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Hey Rick
BEzel was sent to Pat this week
The boxes are a standard 10 inch opening.
Will get you mor eindo when they get here
Old Jul 3, 2010 | 01:47 PM
Gitusum's Avatar
Gitusum
Originally Posted by c5 BearsFan
Hey Rick
thanx for the update and info Dennis as you can see i have a long way to go before getting to that point anyway
i still have to buy all the following
rca cables for both amps
wiring for both amps
back up camera and wiring
decide on where i am going to mount the amps and xovers (thinkin behind the seats)
then make mounts for the amps and xovers
run all the speaker wiring
and i am sure there is something i am leaving out
Old Jul 3, 2010 | 02:16 PM
0Double D Mods
Former Vendor
your forgetting the beer
Old Jul 3, 2010 | 02:27 PM
Gitusum's Avatar
Gitusum
i have no beer but i have some smooooooooooooooothe shine
Old Jul 7, 2010 | 06:40 AM
Dream C5's Avatar
Dream C5
Thats why i havent seen you around, cant wait to see the finished product
To Starting My Complete Audio Makeover Today!
