Sponsored by: Innova
Issues with DNX9960 install. Need help.
Old Jul 5, 2010 | 09:25 PM
Bucknut2006's Avatar
Bucknut2006
Default Issues with DNX9960 install. Need help.
Installed the HU a couple weeks ago and that went pretty well. Everything looks nice and love the functionality of the unit. However, there are now two issues that have arouse and I need some help.
The car is a 2010 w/o Bose and has OnStar. I'm using a PAC Audio OS-2, CM1, and SWI-JACK.
The first issue is a lot of hiss, almost sounding like an amp turned up on high. Another forum member is having the same issue here. http://forums.corvetteforum.com/c6-c...0-install.html. I noticed that in this thread, http://forums.corvetteforum.com/audi...r-harness.html, it appears that both the base amp takes a line level input. If this is true, would wiring RCA connectors to the PAC harness and using the line outs resolve this issue? Is there any other advice?
The second issue is that the unit cut out without audio while driving home a few days ago. Since then, I haven't had audio and the hiss is gone. This leads me to believe that the amp remote signal is not being passed. I found this one the Pac-Audio site under the OS-2 documents even though it says OS-2 Bose. http://www.pac-audio.com/PACProductD...rvette_fix.pdf
Has anyone had to do this work around? Why would the unit stop passing the signal and why would this be the recommended work around?
Old Jul 7, 2010 | 10:38 AM
Bucknut2006
Any thoughts on this? Should I try put the base cd player back in to make sure that everything is functioning like normal?
Old Jul 7, 2010 | 11:05 AM
Klaus-96's Avatar
Klaus-96
2019 Z06 2LZ A8 Coupe
There is a new adapter that member 08VET has used, the Metra GMOS-100. I wonder if that would work any better for you?
http://forums.corvetteforum.com/1574320322-post20.html
http://forums.corvetteforum.com/1574116694-post7.html
http://www.axxessinterface.com/products.aspx?s=gmos-100
http://www.sonicelectronix.com/item_...+GMOS-100.html
Old Jul 7, 2010 | 02:50 PM
Bucknut2006
That looks like a really robust harness. Thanks for pointing that out.
Old Jul 7, 2010 | 03:57 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
jump the remote wire around to the output side of the harness and be done with it, no relays needed that way
To Issues with DNX9960 install. Need help.
