Sponsored by: Innova
Aux button not working ?
Old Jul 16, 2010 | 10:59 PM
DONTGOSLO's Avatar
DONTGOSLO
Cruising
Default Aux button not working ?
I recently disconnected the ground on my battery to reweld the exhaust at the rear coupling left side, factory weld was not even connected ? anyway I re synced my fob and the aux button does not recognize the 12 disc factory cd changer ? I could find nothing in the manual on how to correct this, any help would be greatly appreciated... Thanks MPL
Old Jul 17, 2010 | 03:24 AM
Jistari's Avatar
Jistari
I dont have the changer, but I do run my Aux sound (mp3's from the carpc) through that CorHar harness that runs to your CD changer. Sometimes it fails to recognize my Aux input also if I d/c the battery.
All I have to do to fix it is disconnect whatever is connected there (in your case the 12 CD changer) and reconnect it. If I do that and then hit Aux, it switches from the upfront CD to whatever is on the Aux input. It stays that way until I do something with the battery again.
Hope it works for you.
Old Oct 4, 2018 | 08:33 PM
The Glamorous One's Avatar
The Glamorous One
Default 2001 C5 Corvette Aux button oh head unit not working???
What can I do to fix it? Pull Radio fuse wait a while then reinstall it? Will that fix the problem???
Old Oct 4, 2018 | 10:16 PM
Moved to Audio/Electronics Section.
Old Oct 4, 2018 | 10:24 PM
The Glamorous One
I dont understand what you mean?
Old Jan 14, 2019 | 12:13 PM
bighank's Avatar
bighank
Default Remove plug at CD changer - wait - replace plug
If you remove all power from the CD changer, wait a short time. plug it back in. It will go thru the cycle reading all 12 CDs than it should be recognized by the radio.
Mine was screwed up. Went thru this process. Now it works. DON'T TRY TO ACCESS THE CHANGER while it is going thru the reset cycle or you might get ERR on the radio.
To Aux button not working ?
