Yello Power wire
Jul 28, 2010 | 07:17 PM
Yello Power wire
06-z06 / Kenwood 6950 .
Were is a good place to pull battery power for the yellow wires ?
I pulled red power from the stock connector through the PAC unit , is that kool ?
Jul 28, 2010 | 07:36 PM
Cruise-In IX Veteran
if using the proper harness all wiring should be right there... also see the faq
Jul 28, 2010 | 07:48 PM
The destructions says red wire to switched power , black wire to ground and yellow wire to battery .
I hooked it all up with out hooking up those yellow wires and it wont power up .
Jul 28, 2010 | 08:39 PM
The yellow wire with the knot in the first picture . Does that get hooked up ?
And the yellow wire in the 2nd pic , does that get hooked up ?
It kinda looks to me like its taken care of by the PAC box
Jul 28, 2010 | 09:20 PM
Ok , yellow wire in picture #2 is hooked up and power is on but i have no sound .
Its the factory bose speakers and i used the pac sni-1's for front and rear speakers through the pac c2r-gm24 but get no sound .
The c2r chimes and seems to be working fine .
It seems so simple but yet its not working
Any idea's ?
Jul 29, 2010 | 07:17 AM
