I have a Pioneer AVH4200 DD and I replaced the rears with some Polk DB speakers and the fronts with the Polk DB 3.5" so I'm still using the stock BOSE amps/woofers with a PAC wiring harness.
I'm thinking of adding a sub and an amp and changing the fronts to components. Should I go with a 4 or 5 ch amp?
If I go with a 4 channel amp should it power the sub and the front
components and does that mean that the h/u powers the rears and does that mean I have to rewire the rears as well or should I go with a 5 channel and rewire everything...that also means I don't need to use the wire harness anymore, right? Sorry I get very confused when it
comes to audio wiring.
Once you amplify the system with outboard amplifiers, you should stick with using them to amplify ALL the speakers. So short answer is 5-channel if you plan on running fronts, rears, and sub.
A 4-channel for front and sub with deck powering the rears: you simply won't be happy with it. It makes tuning everything a bear, and the head unit will almost never drive the speakers as well as even the cheapest amp (walmart specials excluded).
If you had to go four channel, there is a good case to be made for dropping the rears. Better soundstage, simpler setup. But that is personal preference.
sorry i disagree a large number of people dont amp there speakers and just run them on radio for rear fill and it works out great
